[AD] Dispoz-A-Blade WoodCentral Special Offer! *LINK*
![]() The ultimate solution for easy, accurate and
Esta Dispoz-A-Blade
testaments about this system?
ron
Rather expensive up-front costs (I'm thinking about outfitting a 8" jointer), but upfront costs get forgotten if the tool performs well. Are there pros or cons actual users can offer?
thanks in advance,
ron
Re: testaments about this system?
I have been using their knives on my 8" Powermatic jointer for many years and find them quite good. The knives are hard enough that they don't dull too quickly, which is a primary concern for me, since I joint a fair amount of exotic wood. And, it's handy to always have another set of edges in reserve. The nicest part, though is that you only have to set your jack screws once, and the holders take care of alignment thereafter. I have not tried their most recent innovation -- tabs that index the holders to the cutterhead itself, but it looks like a winner. It would mean that you're relying on the cutterhead being dead parallel to the width of the tables, which is probably a reasonable bet.
The cost savings is in convenience. You be the judge of that, but I'm not unhappy with my purchase.
Jim DeLaney, Austintown, Ohio
I have them on my jointer and my 15" planer. The jointer setup is the newer one that has tabs to locate the knives on the edge of the head. Knife changes take about ten minutes for all three knives. No adjustments required.
The planer uses 'custom' (by Esta) magnetic spacers to locate the knives. The spacers go under the knife holders, in the bottom of the blade slot in the head, and the knife holders just rest on them - no more jackscrews to adjust. Takes maybe twenty minutes to change the planer blades, mainly because there's some sheet metal to remove for access.
Both sets of blades last quite well - unless, of course, they get chipped. Pricing - after the original investment - isn't too bad. If you have to pay to ship your blades off for sharpening, the Estas are actually cheaper over time.
Yes, Ellis,
ron
Yes, Ellis, your point about dead-on cutterhead occurred to me, and worries me since we're talking about getting within a couple 1/1000's ". Maybe the older system is a surer approach for me.
thanks for saying,
ron
Re: Yes, Ellis,
That would only be a concern with the self-indexing models. Their other models are such that you set the jack screws once and then the height is automatic every time. Didn't mean to suggest that you don't have any options.
