Dog ramp help/ideas please
I've been asked to build a dog ramp for Allie. She is a large (100+ lb) dog who has "blown out" her back knees.
She needs to get into the back of her "mother's" Taurus so she can go to physical therapy. As she is large and out of shape, she needs a wide ramp.
Here are some pics of my first try.
Anyway - the ramp height at the end should be ~ 20". As she is a wide dog, it really needs to be somewhat wide. The slope should be somewhat gentle - as she is out of shape.
So - I need to build another - that will fit into the trunk of a Taurus. I'm amenable to building it in two parts. This ramp has a 40" long hypotenuse or so. The angle is ~30 degrees. The total length is ~ 40" (I have a "bridge" that fits on the end to go to the back seat).
Any thoughts, ideas??
TIA.
Re: Dog ramp help/ideas please
Don Orr
Make it collapsable possibly? No clue how to pull that off but you're a smart guy.
I'd make it fold up
Two sections of plywood with 2x3 cleats on the back, hinged together, with 20" legs bolted under one end.
Modification suggestions.
Keith Newton----Little Rock, Arkansas
I like where you are headed, but instead of using hinges in between the parts, I would suggest using a strap type, and put it on the bottom, where the screws would be in shear, rather than pulling out of end-grain.
Also, move the folding legs out to the outside, for a wider stance, or even better, have some sort of curved metal part that hooks onto the car.
1/2" ply deck should be plenty strong on 2x4 frame.
Dave Paine
I am intimately familiar with this situation.
The first try is too short and hence too steep an angle.
I like Ellis's idea. 5ft ramp feels more likely the dog can climb.
An alternate is a telescopic ladder with plywood inlays. The inlays can be in sections.
The longer the ramp, the easier for the poor dog.
Re: Modification suggestions.  *LINK*
Bill Turpin in WNC mountains
I like the hinges on the bottom with steel slide bolts to prevent buckling. I suggest 1" x 2' OAK side rails, mounted to ply vertically. The endgrain ends of 1 x 2 in the middle need to but each other to help the slide bolts. Put 1" x 2" cross-cleats (pine) every foot or so. Cover cleats and ply with carpet. Be sure that sandwich has hardware to keep closed and easy lift handles. the link is for fancy brass, but cheaper steel should be available.
SLIDE BOLTS
Jim Dillon
JL,
I was at my vet last year and a woman in the parking space next to us had a store-bought ramp for her older dog that was very similar to what Ellis has drawn . I don't remember how it temporary hooked to the rear bumper, but you should be able to rig something up that is safe, yet portable. I think there was some sort of rubber matting or something on the ramp to prevent slipping. The older dog had no problem using it and it sure made sense. Good luck.
Jim
Light weight is the key
Lee Schierer McKean, PA
You need this ramp to be as light weight as possible. Use thin materials that are strong. 2 x 4's and 1/2" plywood are going to make it heavy and hard to handle. There are commercial ramps available and their prices aren't too outrageous in most cases. Unless you are set on making your own design, why not buy one.
Lee
Yonak
..Just thinking out loud here .. How about a board that is as long and wide as the back seat and is carpeted ? Once the dog is in the car, it could store edgewise on the floor or against the seat back with a strap that would hook around the headrest so it would stay upright.
dan arrowsmith
I've been thinking of this problem for a while as my mil has a golden that is in bad shape. How about utilizing a aluminum kitchen step stool, just separate the two legs, add a hinge and then cover with ply on one side. The one I was thinking of using would give a ramp about 5 to 6 ' and would be light and fold, the one I have only cost $40.
How about something like a light frame with cross slats on about eight inch centers and covered with carpet?
Re: I'd make it fold up
Joseph Mulherin
I like3 Ellis's idea for the folding ramp. But I would make the lower one fold up inside the upper section.
Add two 2x3s where the hinges are and make the leg rails just long enough to fit together without binding. That way it would be foldable and have handles to carry around
I'll try a modification of Ellis' idea.  Thanks
