Help cutting out mortise(?) on legs
OneDayJD
I'm installing a cross brace between two legs on a table to run a wine rack the length of the table. Something like this...
Basically, where the yellow cross brace mounts onto the square legs, I want to cut out notches so it sits flush with the legs. I just bought my first router, just an older Craftsman I got from the pawn shop. I'm still learning woodworking and don't have the money to invest so I love some pawn shop tools. I got a set of three Skil router bits, the straight cuts. I am thinking of clamping the two legs together and cutting them out. Do I just need to mark it out, then drill a starter hole the depth I need and then start cutting out the square with the straight router bit? I know that is probably not the best way to describe it, but hopefully someone understands. Thanks for any help.
-TB
Re: Help cutting out mortise(?) on legs
Bart Goldberg
Bart Goldberg
I assume your cross braces are the same dimension as your legs, right? If so, then sure. I'd clamp the two legs together to ensure that the cuts match across the two legs. Yes, mark exactly where the cuts need to be on the legs using the actual cross braces to ensure the marks are correct. Clamp a straight edge across the top and bottom of legs to use as a guide for the router. You need to be sure your straight edge guides are square to the legs, else your final cuts will not fit/be accurate. Set the straight edge so that the edge of the router bit is lined up with your marks. Set the height of the router bit to the depth of cut you want your cross braces to be in your legs (no more than a 1/3 of the thickness of the legs I'm thinking). You probably want to make several (3) passes to get to your final depth. I'd practice on some scrap before doing on the actual legs.
P.S. My advice is based on the info you provided. Ordinary, I'd make mortise and tenons to do this, but that requires more that a just a router, or at least a router with the appropriate jigs.
Bart
FredD
Without a table saw , I would suggest clamping the legs together and usin a fine tooth handsaw or Back Saw if you have one , define the outside of the cuts with a full depth saw cut , then go to the router straight edge.
BTW a router is not required or even in my shop ever used for MT joints.
FredD
If you haven't done this before
Gary Smyth
do test pieces. It's also a good idea to take an exacto or other sharp tool to cut into the surface along the cutout edges to define the area to be routed so that that tear out is eliminated. Use a backer board. If you're new, it will serve you well to limit the travel of the router by setting guides. This will take time and space to set up, but if you don't do it you will soon learn to or suffer with unexpected surprises. No matter how soft the wood and how shallow the cut, don't rout it freehand, at least until you get used to the torque of the motor and the resistance of the wood. But before you do that make certain that everything is clamped so that there is no movement possible of anything other than what you want to move, which is the router and bit. For example, even if you clamp the legs together don't assume that one of the legs won't slide when encountering the spinning bit. A router spinning at 25K RPM will easily move the second piece if they are not solidly together with no freedom of movement in any direction. As has been mentioned, do shallow cuts and use the cross piece as a measuring template to be sure the the routed dado is the correct dimension. Finally with some of the older Craftsman routers be certain that the bit is locked in tightly and that the height adjustment won't change under load. If you aren't aware of the way Craftsman adjustments are designed you can start a cut at one height but by the end, owing to vibration the cuttig bit has risen or dropped. Be sure that all is locked down. From your drawing I don't understand the reason for a drill. I probably misunderstood but it looks like a groove (dado) for rectangular insert rather than a square hole for a square mortise.
Re: If you haven't done this before
Ray Thompson - Middletown, in
I think he is talking about just putting them together in the same orientation as the pic which would create a square to be cut out. We are talking about putting them side by side and cutting across both with the same cut. I would suggest getting a 2by and making some samples before cutting good wood. That will help develop the correct technique.
Ray
