Table saw fence
Table saw fence
Table saw fence
Lynn Reedy
Several weeks ago I posted a note on w.c. about my problems with a table saw fence. I am reposting my note with different info.I have a powermatic 64a, contractor series, table saw. The fence on my saw is a micro glide precision rip fence made and sold by powermatic. I have spent all day today working on the fence to be more accurate and user friendly neither of which have happened. That is what I have and that is what my problem is.
I am interested in either a powermatic accu-fence or a biesemeyer fence for my saw. My question is does anybody out there have either of these fences on a 64a saw and how well does it work?
Thanks for the help,
Lynn Reedy
Soddy Daisy Tn.
Re: Table saw fence
Re: Table saw fence
I have a Biesemeyer Fence on my 40 year old Delta/Rockwell contractor saw. I know that is not what you asked, but I couldn't be happier. Of Course, I bought the fence when Lowe's had discontinued selling them and I got it for $80 and that may be coloring my opinion. (Not Really, that was a gloat.)
My saw had cast grills or ribbed extension tables and the Beis slides on the surface at the outfeed end. So I epoxied 1/4" plywood between the ribs and then ran the wings through my Performax and glued plastic laminate onto them and the additional extension I had made as a router table. Works great. I have not missed the grids at all.
Re: Table saw fence
Rick L
Re: Table saw fence
Rick L
The Biesemeyer is the one that started all the changes in American fences and pretty much all the fences are clones of the Bies so you can't go wrong with any of them. I saw the Bies from the beginning and it changed everything. It was based on the drafting T square. The Europeans had a slightly different fence system already worked before the Bies and that's what Delta copied on the Unifence.
The Htc added a few more bells and whistles to the Bies such as easier replacable sides and a micro-adjuster. The nice thing about the bies is fairly accurate repeatability.
When I worked for a dealer, guys would hem and haw about buying a new fence but once the did they never looked back. One comment that came up quite a bit is they were able to make "an extra kitchen a week!" because of the speed of using the fence.
Re: Table saw fence
Re: Table saw fence
George, Oxford, NC
The Accu-Fence (made by Powermatic) that came standard on my PM64A is rock solid. Something is wrong or missing if yours is not the same. Did you look at the manual that I attached to post on the original thread and adjust the fence according to the manual? You might check the parts list part of the manual and check to see that all of the parts are there and nothing lost or missing. I'm sorry but I just find it had to believe that the Accu-Fence isn't dead on , or can't be adjusted to be dead on.
George
