Selecting Wood
Selecting Wood
Selecting Wood
Terry in Edmonton
I just bought about 20bf of walnut for a project and the exercise of picking it out was a pain. I had a list of what I needed and a tape measure but with the problem of matching the colour and all the random widths I think there must be a better way of doing it.
How do you prepare yourself BEFORE going to the supplier? Just having a cut list and a tape measure cannot be the best way of doing it.
Re: Selecting Wood
Moses Yoder
Re: Selecting Wood
Moses Yoder
I usually just figure 50% waste for hardwoods and get the lumber and bring it home. Then I select the parts I need. One thing to keep in mind is that a door panel does not need to match the frame. It depends on what finish you plan on using, but all the parts do not need to match color and grain so long as the overall effect is one that makes sense. For instance, you could start with darker wood on the bottom, choosing lighter as you go up. Even if you had boards that all came from the same tree you would still need to arrange them for color and grain effects. If I go through my lumber and don't have enough, I go get more.
Re: Selecting Wood
Re: Selecting Wood
Jesse Cloud
Moses pretty well nailed it. Take your time, buy extra.
Another thing I do is to take along a template of tricky pieces. For instance, if I'm trying to find a board with grain to match the shape of a chair leg, I'll make an mdf template of the leg and then try that out on a few boards. When I find one I like, I will use chalk or crayon to mark the shape on the board.
The more woodworking I do, the more I find that spending more time at the lumberyard carefully selecting my wood is the best way I can improve my work.
