Name that drill bit....
What are the drill bits called that have a fairly large shaft (1/2"?) and a very short section of drill bit that is smaller than the shaft. Maybe a half inch of 1/4" diameter drill on a half inch diameter shaft. I think they are made to be very sturdy and not wander around and used to start a hole. I had one I found in a box of junk and thought somebody ground away ninety percent of the bit.
Re: Name that drill bit....
Galen Vetterick
What we used to drill castings in a foundry were callled aircraft extension drill bits. When you needed the extension to drill a small hole through a thin section but had to get through part of the air frame or in our case deep onto helicopter main gear housings.
Perhaps a center drill?
Lee Schierer McKean, PA
One of these?
Lee
Joe Mohnike
You may have an old bit. I have several antique drills, the chuck or holder was nothing more than a 1/2" hole, with a set screw or bolt on the side. I have bits where the cutting portion is up to 4" and some that are only 1". You do not want to use these in modern drill as the speed will only burn them up. They were designed for slow speed, hand crank equipment. I have bits from 1" to 1/8" dia.
I have also seen the same type of bit used on different type equipment, boreing machines, mills etc.
Joe M.
Re: Perhaps a center drill?
Galen Vetterick
I should read what he wrote for description, dah! I got it in my head LONG shank and short drill section. Had center drills with my old South Bend metal lathe. Think you got it.
I think that's it....
I thought I remembered the one I had as being single ended.
What is the function of a Center Drill? Do you just drill an starter hole, perhaps an 1/8" deep and then switch to a longer bit to drill deeper at eh same diameter? Or, Do you drill in deeper and create what amounts to a countersink and then drill through with a larger bit, perhaps a 3/8"?
I am pretty much self taught as a metal worker. That is, I am making it up as I go along. Come to think of it, that applies to my woodworking too.
Re: I think that's it....
They cut more like an end mill, but provide a starter hole for drill bits so they won't wander. Since they are very short and stiff they don't wander like a twist drill. They come in various sizes. On a 1/4" one the pilot hole is about 1/16 dia and the max cone diameter is 1/4. Maybe a machinist can provide a better description.
Lee
Center drill *LINK*
I always thought the original purpose was to drill the hole that the centers went in when turning shafts, as described in the link below.
http://www.sherline.com/3021pg.htm
Re: Center drill
Paul Vander Woude
The proper use of a center drill is indeed as Bill suggests, to create a Hole on the end of a shaft that is to be turned between centers on a lathe. Because they are short drills with a large shaft, they are commonly used as spotting drills, because they won't skate as much as a longer, skinnier drill bit. However, the correct, and better drill bit for spotting holes is called a spotting drill. Do a search on Amazon.com for spotting drills, and you will find a variety of them. They reallly do spot holes better than a center drill, especially in harder materials. Also the nub of a center mill is prone to break off in harder materials at inconvenient times. Oh, and spotting drills seem to me to be easier to sharpen accurately than center drills.
