Kitchen Faucet Question.
I bought an American Standard single lever faucet at the Orange Borg and put it on my kitchen sink. Not a High dollar faucet, just what I thought was a solid middle of the road performer. Turns out the spout is very stiff to swivel left to right. Several times as much force as I thought it should be. I left it alone thinking it might "loosen" up a bit with use. Nope, Still stiff months later. And, when you use the sprayer it doesn't cut off the water to the spout. Sprayer works OK but a lot of water is going down the drain. Don't they all divert the water to the sprayer?
So, would you consider this defective and return it? Would you work on it and try to see why the spout is stiff and the water does not divert?
Re: Kitchen Faucet Question.
Lee Schierer McKean, PA
Some faucets don't come equipped with the internal diverter valve for a hand spray and will allow water to continue to come out of the spout while spraying.
Lee
DavesNotHere
Not sure if I would call it totally defective but it certainly isn't working the way it was designed too. I'd take it back and exchange it for a Moen. I would guess that the spout issue may have something to do with the spout gasket not being seated properly. The spray issue however is caused by the interior diverter not working properly.
I have a near new Moen
Mike Farinella
and it does the exact same things Barry described.
Nat Robison
Mechanics of your faucet aside, I would take it back. The typical 19-year-old at HD won't ask you a single question. I bought a plumbing part at Lowe's and installed it but it leaked (not badly). The original bag sat in my basement for almost a year with the receipt in it. I was expecting a few questions of at least some resistance from the Lowe's employee but they took it back without a single question.
Also, I've usually had Delta kitchen faucets and they seem to divert all the water to the sprayer.
steve mackay
I wouldn't goof with it until I had, at least, tried to exchange it ( Yes, for a Mohen. WITH the ten inch goose neck. GOD, I love it ! ). If they won't do it then noth'n from noth'n leaves nuth'n and you can open 'er up with a clear conscience.
Tony - Memphis
We have a middle of the road Delta in our kitchen. It does turn off the water to the faucet when the spray handle is used. Mine wore out the two o-rings that kep the main body from leaking. After I replaced them, the swivel motion is quite a bit stiffer. If I recall, you could tighten/loosen that fit. I tried to find the point thta it didn't leak, but wasn't too hard to turn and too hard on the o-rings. I was going to just replace it, but after looking under the sink...I was thrilled that some nice person posted information on how to replace those o-rings! Mine is soldered in and VERY hard to get to. almost like they tried to make it difficult. Still kicking after twelve years (and two o-rings)though.
Tony
Steve Schoene
I'd return it, but for a refund. The borg is not a suitable place to buy plumbing fixtures. Go to your local plumbing Supply house. The fixtures sold at the borg may well have internal parts that differ from the ones at the supply house.
about the  Kitchen Faucet Question.
del schisler
take it back for a exchange. I used to work for hd in the plumbing dept. Moen had the most problums even tho it is garateed for life. Just send the part back and they will send a new one. If it were me i would get a Delta they had the best non fail. I have had delta for around 24 yra and just had to rebuild my kitchen faucet. Not bad. I belive around $11.00 for the parts. good luck
On the moen cartrage what happen's is that you get cold water and no hot. You can pull the cartrage out with the puller. Don't forget to take the clip out don't loose i don't belive HD has them any more. Now on the end of the cartrage their is a plastic piece that you can take off and their is a ball beiring in their . Take it out by hitting the cartrage easy on something hard. Now once it is out clean off the lime build up and clean the inside of the cartrage. Simple green will do that. Now put it back togother. Now shake it and the little beiring will rattle. Now the cartrage will work just like new. The old trick i told many of coustomer's. If you happen to be in the cartrage department pick one up and shake it. You will see that the beiring will rattle. The beiring get's stuck in the old one and will not switch when you go to the hot water. my 2 cents
Correction...
Tony - Memphis
Well, I noticed last night that when I use the spray handle, I do maintain a little flow through the faucet. Sorry, I sure thought it shut it off completely. Seems like the more flow you have, the more it shuts off. Oh, and if you wiggle our faucet a little, it will leak some water, but then it stops.
Tony
Do You Have Any Proof Of That?
DavesNotHere
I'm not saying that what you said is not correct however I kinda doubt it is if the model number is identical at both the Borg and the Supply House. Not only could there be legal problems with that kind of practice it would also be very expensive for the factory to do that.
Gary Camp, Bend, Oregon
Get on-line and find American Standards tech support number. Ask them the questions, I had some problems with a Moen kitchen faucet, thier tech support sent me the parts the same day and e-mailed me very good repair instructions. I would expect no less from American Standard.
glc
I suspect
That the model numbers wont be the same from "borg" to plumbing store. Based on an expreience buying a CSM saw, I suspect (with no proof) that tools that barely pass quality control checks go to the Costcos of the world and tools that are right on go to the specialty tool stores. A friend and co-worker who did small engine repair swore up and down that one small engine manufacturer had more than oneglc quality level with the same apparent model number that went different equipment lines. Again no proof.
Re: I suspect
Carol Reed, Strawberry, AZ
Wouldn't surprise me, Gary.
Years ago when I taught wood working, I had a bearing supplier come into class and talk to us about bearings. He told us that there were only a handful of bearing manufacturers world wide and that every bearing that at least spun, had a market, depending on how well they spun. Only frozen bearings hit the dumpster.
I am certain that is true of nearly everything, including faucets and their repair kits. Proving once again, that you get what you pay for. But no amount of money buys perfection.
jsamsen
That is true. Home Depot and other mass merchants (Walmart, etc.) basically tell the vendors what they will pay and tell them to go back to the drawing board to cost reduce if the price is too high. I've had a number of plumbers recommend other distributors other than the borgs for that reason.
Re: Do You Have Any Proof Of That?
Steve Schoene
I've gotten repair parts from the supply house that were different from those that broke in the fixture. We build a new house recently and the plumbers were quite definate about there being a difference--and this was with me supplying the fixture. It wasn't a case of there being a profit opportunity for the plumber.
There have been other examples given. Power tools with different motors.
The big boxes don't have lower prices because they take lower margins--it's because they pay less for products. The common tactic is to place a large order from a manufacturer, who has to expand to supply the new demand--perhaps 20% of sales. Then, the retailer cuts the price--the manufacturer has to find a way, because they can't afford to lose that amount of business especially while they are paying for expanded capacity. Sometimes they have to "reorganize" stiffing the creditors so that the borg can undersell the supply houses by a few pennies.
