bookcase standards
bookcase standards
bookcase standards
Jay Lundgren
I've got a bit of a problem. I'm just finishing up on a set of bookcases and am now just realizing that the dados I cut (16 of them) are about 1/16 inch too small and the standards are not fitting as I planned. I've built lots of cabinets and have never had this problem before. If I hadn't already assembled everything already it would just be a hassle to cut the dados over but everything is now assembled. Any Ideas?
Re: bookcase standards
Dave Bair, Eaton Rapids, MI
I recall that LV-Veritas makes a plane to trim dadoes. They are offering free shipping thru tomorrow. It would seem to be an expensive a solution, though.
An alternative might be setting one leg of the standard (I'm assuming you're using metal standards with a shallow "U" shape) in the dado, screwing it in place and using the leg outside the groove as a guide for a chisel line. Once the line is cut, remove the standard and use a sharp knife to remove the unwanted wood.
Joseph Mulherin
Jay, you might think about cutting a rabbitt on the ends of the standards to make them fit properly.
And a small hand plane will work to shave off what you need.
John McGaw
Is it the standards that are a bit larger than normal or just that you cut the dadoes a bit too narrow? Being lazy, the first thing I'd be doing is looking for more friendly standards. If that failed then I'd opt to route the dadoes via a long straightedge guide.
The thought just occurred that it might even be easier to create a small sled for a trim router with a slide which fits into the existing dadoes and positions the router with a small spiral-cut bit just a bit off-center which would widen the existing dadoes by the proper amount.
Jay Lundgren
All good ideas, thanks. This is a mistake I won't make again. Getting it fixed and getting the standards installed before anyone one sees that I made a mistake may be the problem at this point. My kids still think I don't make mistakes.
I take it your kids are not yet teenagers
Re: I take it your kids are not yet teenagers
Jay Lundgren
They are teenagers. I guess I'm either naive or they're just being nice and letting me believe I'm still superman.
Lie.....
Tell them you set up the rabbets for English tracks and the ones "they" stock now are metric. And we all know that the Metric system is completely incomprehensible and no right thinking American would anticipate such treachery.
Then figure out how to route the grooves out to what they should have been. And, Next time, buy the adjustable shelf strips first.
What the heck is a MM anyway? Just because every other country in the world (except us and somebody I never heard of) uses them, why should I care?
Re: Lie.....
Jay Lundgren
That's a brilliant idea. I'll see if the boys will believe that, I know their mother would!
Gary Camp, Bend, Oregon
If the standards are made of AluminumI would be tempted to run them throught the tablesaw and trim a 32nd off flip them end for end and trim another 32nd off. Or as mentioned before check out different brands, you might find "non-metric" ;-) ones that will fit.
glc
Bart Goldberg
Bart Goldberg
Jay,
If you are a true tool junkie like me, and need an excuse to buy a new tool, then this should
accomplish the trimming you need to do.
http://www.leevalley.com/US/wood/page.aspx?p=60012&cat=1,41182,48945
Regards
Bart
