Eccentric guide bush question
Rob Scrimgeour
I wonder if anyone can help me clarify my thinking about this.
I have a Leigh dovetail jig and a Festo 900E router fitted with a 7/16" guide bush and an 8mm shank Leigh dovetail bit which I use for half-blind dovetails.
The guide bush and the bit are not quite concentric, with the bit being displaced slightly towards the handle, which I hold in my right hand with the router oriented at about 45degrees to the left. I keep this orientation consistently when cutting the tails and the sockets.
Am I right in assuming that the left to right component of the eccentricity will be self compensating for the tails and sockets? but what will the effect be of the front to back component of the eccentricity?
In practice I find that I can use the eccentricity to fine tune my fit, by doing a final pass with the router turned a further 45 degrees to the left when cutting the tails, but I am keen to understand the dynamics here, as I usually have quite a battle to arrive at my final setup. Can someone guide my thinking?
Re: Eccentric guide bush question
Can someone "guide" my thinking
George Koch
Good one Rob! My first guess would be that the router base plate is mismilled (is that a word?) Either the guide bushing insert hole or the screw holes for attaching it to the base. George
Re: Can someone "guide" my thinking
Rob Scrimgeour
Thanks George - not intentional! - anyway, that's beating about the "bush"
I suspect the Festo router to be at fault, judging by comments I've read concerning this issue and a larger and later model of the Festool. Anyway, I have to live with this, but I'm keen to get opinions on the effect this is having on my HB dovetails.
Concentric Calibrator
A. Kapocius
Not entirely expert on this subject but isn't there calibrator rods that can be chucked into the router to adjust the base?
Al Kapocius
Dave Bair, Eaton Rapids, MI
Setting up is made easier by reducing the number of variables you have to deal with. For the router itself, this should be limited to bit height. I'd find a way to center the bit and bushing; my Bosch router allows me to move base slightly by loosening the screws, adjusting the base and carefully retightening. I also have some play in the bushing attachment.
AZ in Colorado Springs
How about this? Set the router on the jig, and kneel in front of it, with your eye level just under the router base. Slowly rotate the router until the bit appears to be centered in the guide bushing. Then you can stand up and see the angle of the router handle and you'll know how to hold the router to get the tails and pins centered.
Then, with the router oriented the same way, but probably not atop the jig, you ought to be able to look at the router from the side and see how the bit is oriented from front to back (off by 1/16 or 1/32, etc). I believe since you route the half blind sockets from the inside face of the board, if the bit is toward the back of the guide bushing (away from you), the socket will be deeper than you intended.
I've found this to be the easier adjustment, anyway, and if the socket is a hair too deep, you can align the outside face of the tail board flush with the edge of the pin board when you glue them up.
I went to the woodworking show at Denver last November and got the template set from Peachtree woodworking for decorative dovetail type joints. I had to drill the mounting holes for my Freud router in my router table insert plate and it is just a bit off. I've had to deal with a similar misalignment problem. (Rockler does not have predrilled router table insert for my model of router.)
Rob Scrimgeour
Thanks for the input AZ - I think that the sideways offset is self compensating as far as fit is concerned, but will have an effect on the relative sizes of the half-pins on either side, so I will do as you suggest on my next set-up. One can compensate for depth of cut on the jig settings, and one needs the pins to be slightly proud anyway for final sanding so perhaps the front back offset is not too important.
My thinking now is that its not a bad thing to be able to rotate the router on a final pass in order to sneak up on the fit.
Anyway the present setting and method are working for me on the batch of drawers I'm busy with, so I won't rock the boat, but I will do some thorough tests before my next set-up. Thanks again
Rob in South Africa
