SawzAll Blade Change question
I have an older Milwaukee SawzAll and you use an Allen Wrench to change the blade. The newer models have a twist lock that does not require tools to change the blade. Anybody been using the toolless blade change? Does it work well? Is it reliable and hold the blades well? And, could it be retrofitted to my old saw?
Re: SawzAll Blade Change question
Stuart Johnson
Mine has the twist blade holder. I have not had any problems with it not holding the blades. It is twisted and held when inserting or removing blades and sometimes it feels a bit awkward but not really a problem. I have no idea if your can be adapted.
Joe Mohnike
I have a Ridged and it only has a flip lever, it seems to work and hold ok. My old saw had the allen wrench type holder and the blades always came loose.
Also keep your old blades, the thicker ones make good marking, carving and utility knives.
Joe M.
John McGaw
I have a newer VS Sawzall with the twist lock and it has never let go of a blade accidentally. Quite the opposite -- sometimes it refuses to let go when I want it to and that sometimes results in a long struggle.
Jim Rahbe, Bedford Texas
I love that thing..
Barry,
My Milwaukee Sawzall is a tool that I would buy again five times over. I love it! Mine has the twist lock blade holder, which works very well.. I use it to cut all kinds of crap.. sewer lines, sheet rock, etc, so it gets pretty dirty. This causes the twist lock portion to become hard to turn or not turn as far as it should. When this happens, it makes getting blades in and out a little difficult, but a little WD-40 fixes it right up. If I took better care of it, I doubt I�d have this problem.
I have no idea if it is possible to update your saw or not, but I suspect it would cost almost as much to retrofit one as it would be to buy a new one.
Jim R.
Howard Norman
Barry, I have an older SawzAll like you. The only problem that I have ever had with the Allen wrench blade removal system is that once in awhile I will forget to put the wrench in the holder and will have to hunt for the proper size Allen wrench. Come to think of it I don't think that I have had that problem in the last couple of years so I must be getting better about putting the wrench where it belongs.
I would say that the purchase of a real SawzAll was one of the best tool purchases that I have ever made.
A Quick Phone Call........
DavesNotHere
A phone call to the nearest Milwaukee Service Center should get you an answer if it would be possible to retrofit your saw. I gave my really really old but still perfectly working Milwaukee Sawzall to my brother over a year ago and got a new Milwaukee Sawzall. The new one has the tool less blade mounting feature and so far it has operated flawlessly.
Clint Searl
Go through a lot of blades, do ya?
Clint Searl
Yesum do....
I think of the Sawzall as the closest thing I have to a Light Saber. I have remodeled four housed recently and the Sawzall has gotten a workout. It always seems to have the wrong blade. Metal cutting blade when I need to cut wood and ...well, you know. Its one of those "real" tools that I would replace the same day if it gave up the ghost.
William A. Roland
William A. Roland
In my experience the flip type release does not hold the blade firm, it is very floppy and makes it hard to make a precise cut. I think the twist lock works much better. I don't know if it can be retrofit.
Paul Vander Woude
If it is a Milwaukee, replacement parts are pretty easy to find. Here's a site:
http://www.ereplacementparts.com/milwaukee-sawzall-parts-c-131_5093.html
Some of the models list a kit for the quiklok blade clamp parts, such as this:
http://www.ereplacementparts.com/steel-quiklok-blade-clamp-kit-p-128618.html
Find your model, and then look for a similar model with a quick change blade lock, and see if you can get the parts you need.
BTW, I love the quick change blade. I've never had any kind of a problem with it.
