We value your privacy.
I'm building an octagonal bird house. I tilted my table saw blade to 22.5 degrees and proceeded to rip 8 pieces the same width. When I put it all together, there was a gap of approximately 1/4 inch.
I assume that my 22.5 degree tilt must be off by a hair. If so, do I decrease it slightly?
If I'm wrong, what do I need to do to close the gap.
You need the angle to lean over more - but this can get tricky; 1/4" isn't much, and it would be easy to overcorrect. One alternative is to glue up the birdhouse in two halves, and then flatten the remaining edges with a hand plane (if you're good with one) or two sheets of sandpaper taped to your tablesaw table (if you're not good with hand tools), then mate the two halves. It won't be a perfect octagon, but very few birds carry measuring tools precise enough to notice the difference; and if they're that fussy, you don't want to be renting to them anyway.
You did not say which side the gap was on or if it was a single gap or a gap at every joint. If it is one gap and lats say its on the out side of the octagon then you need to tilt the saw more, but only slightly. Conversely, if the gap is on the inside of the tube, then you need to tilt it less. If it is a total of a 1/4 inch you need to change it a tiny amount, maya degree. If you have a good sharp blade and you dimension is not critical, you could run them all again. I would look at it and decide if I needed some of the "heel" or the "toe" and adjust and take another whack at it.
I made a bunch of such multi-sided tubes and then put them on the lathe and turned them into cylinders. On those, if they weren't perfect I tried to leave the gap and the toes and turned that part away. I glued all of mine with Titebond three, but is your joints are a little sloppy you could use Epoxy.
By the way, I laid mine out with the outside up and applied a couple of strips of tape to them. Turned them over and put glue in the cracks and rolled them up and clamped them with big hose clamps or strap clamps.
if you had a beall tilt unit it would get you right on the 22.5 degrees . this unit is what i have and it get's me right on. You can use it on any tool that has a blade and table also on a drill press . And set up your table saw for the 90 degree's. And set your blade on the table saw right on 90 degree's. I wouldn't be with out one. Their is also a wixey unit . The beall is better It uses a 9.0 volt battery for longer life. I cut oct. all the time and they fit very will. Good luck
Get yourself a 22.5-degree chamfer bit and go for it. Or, if you are thinking about the process of clamping the finished assembly with dread, buy the proper 'bird's-mouth' bit and both the making and glueing will be simple. Neither type of bit is expensive.
By the way, when making hexagon or octagon birdhouses, I've always found it just as simple to make the assembly 3+ feet long and then cut out the length for each house.
You didn't give any dimensions, but here is how I would figure that off the top of my head. You have eight sides, with two edges, so there are 16 bevel cuts.
An acute angle with one side 1/4" and two sides 14 5/16" = 1�, so if you house measures ~ 28 5/8" across, which probably isn't far off, maybe, your angle cuts were off 1/16 of 1�. Most woodworking tools are hard to set by that precise amount.
I usually try to practice methods that fudge in my favor. If you cut the angle sharper, the outside, or viewing side will be tighter, and of course, the inside probably has a wall hitting in the angel, covering any opening as well.
Having said all that, I would almost bet that you could just force that small amount closed without breaking anything. And if it did crack a joint, burnish it closed, and go on. After all, it is only a bird house. I promise you, the birds will never notice, or complain if they do.
If this is a martin house, I love to watch those birds. Lots of people think because they catch flying insects, that they eat mosquitoes. But something I learned after becoming a macro nature photographer, and becoming fascinated by dragonflies, and damselflies. They are the extreme mosquito eaters, and they are the size insects that martins prefer. Mosquitoes are too small for martins to be interested in, so having martins might increase mosquitoes in your yard.
Try hand-planing the edges a bit more acute. Just pinch each piece between bench dogs, with one edge hanging over the edge of your bench, and plane the inside of the edge with any plane you have handy. It's a skill to take the shaving just off the inside edge and maintain that angle until you're taking a full-width shaving, but it's not terribly difficult, and you don't need to be absolutely precise. You should have the joints fitting in just a few minutes, with no fussing about machine setup, just the whisper of your hand plane. Or do as Bill suggests and glue up the halves and then plane the edges. Holding the work is a little trickier, but the result should be nigh-on perfect.
Before you cut the parts for the next house, tilt your TS blade just a whisker further over and test fit the joints before committing good wood to it.
Many thanks for all the helpful suggestions. After reading many of them, it dawned on me that the gap I had was even (meaning it was not pie shaped) so I concluded that my angle must be pretty close. I tweaked the jig I was using to line up the pieces and everything fit nicely.
When I build octagons, I use tape on the outside of each joint to hold the pieces together and then fold the octagon into shape. This will help you get all eight pieces lined up at once. You can also use the tape as a clamp for gluing, though I prefer to back it up with a nylon strap clamp once everything is glued.
