Composite Decking Products
Paul Leuba
I am about to replace the deck boards on a side porch on my house that is only about 6' x 6'. I would like to use a composite material because their dark gray color coordinates with my house trim, and I like the prospect of using the invisable fasteners rather than screws through the decking.
The porch is covered and does not receive sun, snow or rain. Just some wet shoes during inclement weather. It does have a tendency to get the green algae on it in humid weather. The decking is attached to 2"x8" joists that themselves are atached to 4 corner posts about 1" above a concrete slab. As a result, the air circulation is limited to what gets between the slab and the joists, a 1" gap on three sides.
Is there a particularly good composite decking product that I should consider for this small project, or should I just pick out something that looks good at the local box store?
Thanks for any feedback!
Paul in Hunt Valley, MD
Re: Composite Decking Products
Dave Paine
A big factor in your options is the spacing of the joints.
Some of these materials need 12 in spacing of the joints.
I used ChoiceDek from Lowes which allowed 16in spacing, due to the material being thicker than e.g., Trex. Mine was a brown which is fading as expected. This is now available also in a grey. Some other materials are available in more shades.
This is used for a walkway over my garage which has no shade.
So far working well.
I did use the special screws which have dual threads, coarse for going into the joints and finer at the top to pull in the material to avoid a "mushroom" effect. Not cheap, but they work well.
The box stores seem to sell only in long lenths, 12 ft or 20ft. Sounds like this should work for you.
woodenleg
I have 2 decks that have Trex on them. Spacing of joists are important, 1 deck is in full sun most of the day and in all weather, I ( in the spring ) wash it with a mixture of Simple Green and a very small amount of bleach, it makes it look clean and stops slime. It does get very hot. Number 2 deck is covered and gets just a small amount of weather and I do nothing with it. Good Luck Dave PS My decking is tongue and grove.
Paul Leuba
Thank you for the feedback. The deck joists are currently 16" apart, but it would be a simple matter to add a couple more if necessady when the old deck is removed. It sounds like the big box store products in composite decking are performing well. I will take a look at both Lowe's and Home Depot.
Thanks for the feedback.
