Re: old, new clock
pete labelle
Hey Joe -
Level or not, listen to the beat of the clock. It should be an even tick-tock-tick-tock. If it is a tick tock........tick tock........tick tock, the verge is out of adjustment. Some clocks have an "auto-beat" feature where, after the clock case is made stationary, swing the pendulum as far as it can swing, then let is settle out. This his how to adjust it. Older movements needed link bent a bit. This incostent beat is the biggest reason many pendulum clocks don't perform for first time users. Almost got an older grandfather clock for this reason till I talked to the owner on this subject.
Clock oil only on a clock. Period. Oil only the pivots and never the gears. Bout every 2 years. A half drop only.
As you regulate the time, it will take a few months to tweak it in. Adjust the screw no more than one revolution at a time. Eventually you will be doing fractional turns. Turning the bob screw to raise (speed up the time) the bob can be done directly. If you need to slow it down, there is backlash between the bob and screw. Gently turn the screw to turn pull the bob down. You will feel some easy movement of the screw, then a bit more pressure when it starts to move the bob. Once you have moved the bob, turn the screw the other way so it now suppports the bob, else the bob can drift down farther.
Did you know, that 150 years ago, when big clocks were shipped to people, they often included a cheap sun dial to set it? After all, it was only when Western Union came along that they were able to syncronize clocks between cities & states !
Pete
