How Am I Fixed For Blades?
Need to do a fine crosscut in maple on a friend's 10" RAS because the piece is beyond the capacity of my slider, and too long and heavy to try on the table saw.
I don't think he's got a good cross-cut blade so I'm wondering, I can use one of my fine-cut table saw blades on his RAS?
tia
Re: How Am I Fixed For Blades?
Jim DeLaney, Austintown, Ohio
What about the blade off your slider? That's what I'd use.
NG
The ras is 10", the slider's 12".
John Veerkamp
RAS and TS blades are interchangeable. It is the tooth design that determines its fittness for the task at hand.
Clint Searl
Clint Searl
Shouldn't be a problem, just feed slowly. It may be best to cut with his blade a 64th long and finish with his or yours, depending on observed quality.
Clint
Moses Yoder
Moses Yoder
The radial arm saw blade typically should have 0� hook or maybe a slight negative hook. This keeps it from grabbing and kicking forward into the board, stalling the blade and breaking your arm. But for a few cuts done carefully a regular table saw blade will work on the RAS.
Main thing is the hook angle on the teeth...
John in NM
For a RAS you want as little as possible or even negative hook. Otherwise the saw tends to ride up over the board if you can't hold it back. I once used a friend's RAS that had a 7 1/2" framing blade on it - with about a 20 degree hook. Man that was terrifying! :D
It's a pull push thing.
I assume you are trying to cut that plank you posted a picture of the other day.
I have had a RAS for years and did not even know there were blades for it. That negative hook thing is wonderful. Wish I had known thirty years earlier. That said, I cut lots of stuff without one. You feed gently into the edge of the board and then hold the saw back, resisting the forward punch of the saw. Sort of contrary, but if you sort of lean into the saw it becomes second nature.
Rather than practice on your plank, I think I would set it up and cut it with a router. Clamp a straight edge across it and use a good sharp bit. Make about four passes.
Clint Searl
Clint Searl
Mark, if you want to schlep it over here, you can use my Delta 10" RAS with plenty of support. I have good blades.
Clint
clay foster
Maybe I'm missing something, but I've always wondered why people fight the RAS by pulling it into the wood and then try to keep it from climbing and running at them, instead of pulling the saw all the way out first, slide the board into place, and then push the saw back across the wood? The RAS seems to be the only circular cutting tool used backwards.
Moses Yoder
Moses Yoder
What you are describing is actually pretty dangerous, having the blade out in the middle of the table while moving your hands around it. I suppose you can stop the blade each time before you make a cut but that would get old real fast. Plus, if the blade cuts as you push back it would tend to kick the boards up off the table.
Also...
John in NM
You get a few inches less cross cut capacity this way - sliding chop saws can plunge so you don't have this problem. Main reason for me would be what Moses outlined - though I guess you could slide it out, put the board back there, then turn it on. Where I used one often was a production shop though, and we used the RAS for a lot of rough cutting, saw would be left on while placing boards as it took a relatively long time to wind down.
That might be a solution!
Re: It's a pull push thing.
Won't do, Barry, the cuts will be beveled at 75�. I don't want to even thing about cobbling together a router jig to do those two cuts! :O
Hand saw would be done by now?
mdclor
So Would Using
A maul and chisel which, BTW, is still an option. I've always been sweet on the lightly scalloped chisel-polished carved surface for end-grain; just don't think it would go with the rest of the cabinet.
