HVLP Unit?
HVLP Unit?
HVLP Unit?
Tony - Memphis
My current project is a set of three bokocases for our great room. That's a lot of painting! Especially all of those inside corners. Anyway, I was thinking I might get an HVLP to use for this and future painting and maybe some finishing. I figure it's one of those things that once you have one, you figure out lots of things to do with it. So, what is a good general use unit? I'll use latex for this project. I might want to use some oil based and perhaps even shellac at some point. Budget is limited, of course.
Thanks,
Tony
Re: HVLP Unit?
Re: HVLP Unit? *LINK*
mdclor
Tony,
There are many units and types-airless, HVLP, LVLP, etc. If you go with HVLP you will need a compressor unless you decide on a turbine unit (3 0r 4 stage). Also, you will need needles and nozzles appropriate for the finish you want to spray-latex requires larger openings than shellac since it is more viscous.
Once you get that all sorted out, you will need to practice with your sprayer since inside corners can be a little problematic. It would be best if you could finish the cases with the backs off and attach the backs once all the finishing has been completed.
The Earlex units are about as inexpensive as you are likely to find, but I have no experience with them. Others on this site have and use them. When I was in the market I talked with Jeff Jewitt and went with his recommendations. He is extremely knowledgeable and a good person.
FWIW,
Merle
http://homesteadfinishingproducts.com
Re: HVLP Unit?
I couldn't agree more!
Gary
Re: HVLP Unit?
Re: HVLP Unit?
Ken Krawford
Tony, I've had an HVLP sprayer for at least 15 years. It is a 3 stage turbine driven unit that I paid $600 for. When I first got it, I was spraying primarily clear finishes and it worked like a charm. More recently I am using paint type of finishes and don't find this to be an ideal unit. It seems that I have to thin these types of finishes excessively and this leads to runs and sags. If I were looking for a sprayer primarily for paint, I think I would consider an airless unit.
I second the recommendation to talk with Jeff Jewitt.
Re: HVLP Unit?
Hank Knight
I concur with those who suggest you talk with Jeff Jewett at Homestead Finishing Priducts. He is an excellent resource; knowledgeable, honest and won't try to sell you something that doesn't suit your needs. If you already have a compressor, I suggest you spend your money on a good gun rather than a "system." Jeff will tell you what will work best for your application.
Homestead Finishing Products
