Festool Rotex 125 dual sander
Dale Lenz
Dale Lenz
Think about springing for this sander. Anyone have any advise concerning this sander?
Re: Festool Rotex 125 dual sander
Jesse Cloud
The Rotex sanders are first rate. They have two modes, switchable at any time, a standard random orbit and a much more aggressive 'rotary' mode. Dust collection is darn near 100%. If you haven't already done so, you might want to compare the RO 125 to the wider RO 150 (bigger sanding surface gets the job done faster). Also, take a look at the new RO 90 - smaller but it has two heads - a round one and a triangular detail head.
The sandpaper is not proprietary (you can use a product made by 3M) but its not generally available at the big boxes. Good news is that F******* (saying the german F word is asking for trouble on this board) prices the paper at about average market price. Don't buy a lot of this paper, though. I have found that with the improved dust collection you the paper lasts a lot longer.
The other good news is all F****** tools come with a 30 day money back return policy, so you can use it for a month and get your money back if you don't like it.
Seen the same thing with paper...
John in NM
When I started hooking my vac up to a cheap Ryobi sander, my paper consumption dropped noticeably.
Both F****** ( :D ) tools I've used had fantastic dust collection.
Jim DeLaney, Austintown, Ohio
I've had mine for about five years, and it's seen a lot of use. Best sander I've ever used! I also have the 125mm (5") ROS, but find myself using the Totax version about 95% of the time.
Dust collection is great - and even better if you make the center hole in the sandpaper bigger. Older paper had about a 15mm hole in the center, but for some reason the hole in the newer stuff is much smaller. Since the sander blows out the center, and sucks from the perimeter, the air movement is much better with the center hole enlarged. Dust collection is excellent - nearly 100%.
Yeah, the sander is pricey, but I think it was worth it. YMMV 8)
matt overton
This is a great tool. It more than paid for itself when I sanded 1500 bf of Ipe all sides for the deck that I built. It is better than any other sander I have used, by far.
Dale Lenz
Thanks for all the replies, so far.
Dale Lenz
I can sand outside often, so do I have to use Festool or 3M's 5" disk? I have a boat load of 5" disk for my DeWalt, 5 hole sander.
Christopher Fitch Memphis
I have one...I like it alot.
Very versatile. It requires a light touch...you can rough sand, finish sand, and polish with it.
You can use Abranet and Abralon with it as well.
Re: Thanks for all the replies, so far.
Jesse Cloud
Rotex sanders come with hook and loop (in Festool speak "Stick and Fix") pads, so 5 inch h&l should work if you are working outdoors and don't care about dust control.
I guess my question would be what leads you to be interested in the RO 125? Even a Festool fan like myself would think its a lot of money to spend on a sander you would use without dust control.
Jason Roehl in Lafayette, IN
Paper longevity is not just due to DC...
For one, it's good paper, but it's not that much better than other brands (I like the dark red stuff--Rubin, maybe?).
That aside, though, DC is important for a couple reasons. One, without it, the paper will ride up on the sanding dust, reducing sanding effectiveness, and wearing out the paper more quickly due to re-sanding the dust. This also may cause the user to apply more pressure, which leads to the second reason for DC--cooling. Heat is the #1 enemy of sandpaper, and having a shopvac attached to suck the dust out also provides airflow on the paper, helping to cool it and make it last longer. That's why the Rotex models have the hole configuration they do--the air flows out from the center hole and in through the holes that are much nearer the perimeter than other sanders.
If you use the eccentric-orbit mode, it's much more aggressive, but HANG ON!
Jason
To clarify...
John in NM
My comments were not in regards to F****** products, rather dust collection in general. The only thing that changed in my setup was the addition of a vacuum, sander and paper remained the same. I'd suspected it had to do with dust loading between the grains, the same sort of effect one sees with a bandsaw blade that has too many teeth or too small gullets to clear the dust - cutting slows.
Not sure heat could much of the problem. Less is better of course, but I've yet to find an orbital sander that gets too hot to touch, and surely the paper manufacturers could find an adhesive that can withstand 140F.
Dale Lenz
Festool, all about dust control?
Dale Lenz
I want a sander that is quick and does a good job at the same time. I thought that Festool and Fein does that. I've made a quick drive by the 90 model, might change my mind(?).
Re: Festool, all about dust control?
Jesse Cloud
I guess I have just gotten so spoiled with clean indoor sanding that I was surprised that you were planning to use it outdoors. Take a look at some of the threads in www.festoolownersgroup.com - the festool user group forum. There is one where a guy takes a totally rough board, smooths it down, and then polishes it to a piano finish in a few minutes.
If I were buying a sander now, I would give the RO 90 pretty serious consideration, especially if you work on site - fewer tools to carry is better and the 90 with the round and triangular combo along with the aggressive and rotary modes is a jack of all trades. With the 30 day full refund policy, there's no reason not to try...
Dale Lenz
Thanks, Jesse,
Dale Lenz
Started to look at the RO90, Hummm.
Check out Abranet
charlie belden
Because it's a mesh, dust is sucked through the entire surface rather than throuh 5 holes.
Costs about three times what paper does - but last at least five times longer - and can be washed - or soaked in alcohol to clean if you've been sanding shellac.
