Bending Oak
Bending Oak
Bending Oak
Ed Wesolek
Hell-o People,
It is a beautiful day here in Michigan with the sun shinning and a bite in the air. I hope that everyone is in their shops working on projects. Just finished spraying 4 tables that we made and looking to get the second coat on today.
While we were working we discussed the bending of quarter swan oak. What we would like to do is bend it the easy way for the back of a chair. We are thinking about soaking it first, yes the piece is dry at 6% & 3/4 inch thick, then use a steamer to soften the wood enough to start bending it. Once we do get it bent into shape, clamp it and then let it dry.
Does anyone have any experience bending wood and or steaming it? Do we put anything in the water to help it soak into the wood? I wanted to ask to see if we are on the right trail and if it will work or not.
i wll chcek back in on Monday as we are cutting trees and working on the tables.
Thanks for your help.
Ed
Re: Bending Oak
Piece of cake...
doug f, san clemente, ca
Ed - I bend QSWO frequently for chair backs and slats. I also build Shaker boxes with QS Cherry. The Cherry I just soak in hot water (about 185 degrees) for about 20 minutes, but the Cherry is pretty thin.
White Oak I steam for about a half hour, then bend over forms and clamp until dry.
With a bit of practice and some patience, you should be able to bend it quite nicely.
Have fun with your project.
Doug
Re: Bending Oak
Here is the best advice I can give.  *LINK*
Keith Newton----Little Rock, Arkansas
The link below if for the most concise information to guide you through the usual pitfalls, and help you understand the answers to questions you probably don't know to ask, plus it is free.
http://www.leevalley.com/en/wood/page.aspx?p=31161&cat=1,46096,46123
Re: Bending Oak
Re: Bending Oak
Jesse Cloud
Good advice above. I would suggest that you try it first with a piece of scrap of the same species and thickness, just to get the feel of how much springback there will be, etc. 3/4 should be easy to bend.
Re: Bending Oak
Re: Bending Oak
If the wood is air dried - I would steam it and bend it. I typically steam for about one hour per inch of thickness or diameter. If the wood is kiln dried - you may expect some failures unless the curves are gentle.
My experience is primarily with green white oak. I have bent air dried walnut, hickory and other woods.
