Table saw fence
Table saw fence
Table saw fence
Lynn Reedy Soddy Daisy Tenn.
Good Evening Folks,
Last week I posted a note about a outfeed table for my saw. It is now apparent that first I need to change my fence. I have a powermatic contractor saw model 64a, 10 inch. My question tonight is "what are the pro and cons about a 50" accu-fence by powermatic and a 50" Biesemeyer fence"? My present fence came with the saw and accurate it ain't. Both ends of my present fence ride on angle iron and it never is straight.
Thanks for the info..
Lynn Reedy
Re: Table saw fence
Dale Lenz
Re: Table saw fence
Dale Lenz
Have the Beis Professional 50" fence since 1983, like it and would get another if needed.
Re: Table saw fence
Re: Table saw fence
Dave Paine
I had a Bies "commerical" fence on my previous saw, and the new "black" Bies fence on the new Delta Unisaw.
Both are solid performers and I would recommend.
Easy to calibrate and stay in calibration.
Even easier to use.
Re: Table saw fence
Re: Table saw fence
Robby Wright in San Marcos, CA
I've had the Biesemeyer pro 50 inch fence for close to 30 years and I love it. Simple, accurate reliable. Some of the best money I have spent on my shop.
Re: Table saw fence
Re: Question? Table saw fence
Henry (Raleigh, NC)
Lynn: Disregard all of the below if you truly have determined that your existing fence is truly unusable and not just out of alignment.
Is the current fence a very old model? What model is it?
Powermatic is a reasonably well regarded name in the business. I'd be surprised if it came with an unusable fence. Of course there could be many reasons why what the fence may be unusable: a very old TS, purchased used, damaged, or never installed properly.
Many of the fences made in the last 20(?) years can be adjusted to run true and cut accurately, once the rails are installed correctly.
Have you tried looking up the model of your current fence and finding a owners manual, then re-installing? That may not be any more difficult than installing a new one.
Of course, there are several name brand fences that are wonderful to use. I have a Vega fence with 52" rails. It is a delight, especially the micro-adjust feature. The name does not come to the top of the list when people consider fences, but it is a very good product that I believe is cost competitive. And that micro-adjust feature is worth it's weight in gold - Powermatic color joke there :)
Hope this helps.
Henry W
Re: Table saw fence
Re: Table saw fence *LINK*
George, Oxford, NC
I have the 64A with the Accu-Fence. Mine is as stable and solid as you can get. I bought the saw used over ten years ago and when I first got it, I moved the 30" fence to the right to give me 36" cut capacity. I then went through and aligned the saw and fence. I have not had to look back. The first thing I would do is to look at the adjustments on the fence, including, as someone said, the rail installation. There is nothing wrong with the Accu-Fence.
If you don't have it, the manual for the Accu-Fence can be found here
http://content.wmhtoolgroup.com/manuals/M_2195075Z.pdf
George
Accu-Fence Manual
Re: Table saw fence
Re: Table saw fence
John M in Mid Mich
You didn't ask about it, but let me just suggest you not overlook the Incra TS-III. I replaced a Biesemeyer clone (Jet Xacta Fence) on my cabinet saw with the Incra and it has transformed my tablesaw work. Accuracy and repeatability are incredible. I could never go back.
