Calling Fred Davis
Dale Lenz
Purchase some of that SW wood filler you posted about a few months ago. So what do you use to get the stuff into solution. It's caked up against the side of the gallon can like black gumbo mud!
Calling Fred Davis
Dale Lenz
OK Calling FredD
Dale Lenz
Re: Calling Fred Davis
FredD
You must have a really old can Dale. it can be pretty stiff , so I use a paint stirrer made for stirring five gallon paint cans and drywall compound and chuck it in a 1/2" drill motor .
Works really well .
If the filler looks to dry , cut it with a little Mineral spirits and some linseed oil.
Try power blending first .
You should get a consistency of mashed Potatoes or heavy Cream before you apply it.
FredD
Dale Lenz
Got on of those 1 gallon stirrer thingys & did hook up to my 1/2" hand drill. Put all the "mud" into solution, took 20-30 minutes. The consistancy is no where near mashed tators. Might need to leave the can open for a few days(?). Think the date of mfg. was like 2009(?). Will try in the next few weeks, will let you know how it works. Thanks for answering my ?
FredD
Dale , when I said Mashed Potatoes, the kind my wife makes in a hurry sometimes from dried stock is closer, maybe not the old fashion stuff with chunks in it. ;-))
Also the consistency of the heavy cream we got from a Jersey cow is ideal.
The payoff will come when you have a truly flat surface without any canyons in it.
A tip if you haven't done it before is to make sure you have it all scraped and wiped off before it dries , it will load sand paper , so that's not a option.
When the filler becomes hazy looking , scrape across grain with a straight edge, then get on it with Burlap or if you can still get some , we were taught in the shop class to use Excelsior.
Haven't seen any in years.
FredD
Dale Lenz
Thanks, Fred...I'm almost through with my second qt. of the brand Jeff's website sells, something like 30 bucks to my door, SW stuff was $60 something for a gallon. The brand on Jeff's site begins with a B, I read it is being taken off the market.
I use an old credit card to spread and remove the filler material. Also use burlap to rub across grain.
