Re: out door stuff using trex
Dave Paine
I replaced a section of decking over my garage with the Lowes ChoiceDek.
I am happy with how this is performing. It is thicker than Trex and so far feels to support my weight. This is a walkway so only get passing weight.
I made a cover for a septic tank access hole in Trex. This was 2ft x 2ft. No weight, just keeping out the bugs and critters. I screwed supports in below.
After 1 summer this warped so much it pulled out the screws. I have to re-drill.
Still is shows severe bow. Perhaps over 1 inch over this short 2 ft stretch.
I have to agree with the other replies. If used as decking it may work, but as furniture, I do not expect you will like the results.
If you really want to experiment, try the Lowes ChoiceDek.
If you want real wood, consider the tried and true white oak. Used for barrels and how many whiskey barrels have you seen which failed during use?
