*** SURVEY: THE IDES OF MARCH *** *LINK*
Hi Folks,
Welcome to the 69th (!) bi-monthly "Ides" survey here on WoodCentral.com. Hmm, that would be about 11 1/2 years worth of surveys. Whew! I'm amazed that there are any questions left to ask, but sure enough....
This month's survey question is about a side of our craft that nobody wants to think about: Workshop accidents. I'm interested to know if you have had one (or more) accidents in your woodworking past and what you learned, generally or specifically, that might help other woodworkers to avoid similar mishaps.
As always, your responses will be sensitively edited and transmitted to Woodworker West magazine and will appear in their next issue, due out in April.
Thanks in advance for participating!
Ellis Walentine, Host
Woodworker West Magazine
Re: *** SURVEY: THE IDES OF MARCH *** *LINK*
Gary Smyth
Here's mine. A cut down version of the original 70mm baltic birch ply board. It flew off the table saw before I ever saw it. I was 20 inches away from the blade at the rear of the saw. The end of the board hit me just to the left of my sternum. The circumference (perimeter) of a 10-inch saw blade is 31.4 inches. If the saw blade travels at 4,800 revolutions per minute (rpm), then the teeth are travelling at (150,720 inches per minute, that�s 9,043,200 inches per hour, or) 142.72 mph! I was stunned and simply fell/sat back on my butt, legs outstretched in front of me.
When I recovered enough to look, I had a huge black/purple outline of the end of the board on my chest. Even today, six years later, there is a small right angled scar where the skin was so traumatized that it formed a lumpy area even though the skin never broke. Much later, a Doctor let me know that the hit was similar to being too near a explosion, and that the area suffered blunt force trauma. He stated this might be the cause of a heart murmur that wasn't there before experiencing the hit.
Lessons learned. Whenever possible include in my set up a splitter. Never cut a board on the table saw wider than it is long without support beyond my hand. Check the fence for squareness regularly. When I'm working at the saw I often wear a short baseball chest protector (used sporting goods dealer $5) and full face shield. (If I'm alone, I feel safer and no one sees; if I'm not alone I'll take whatever ribbing is certain to occur.) Finally, I always have the plywood board available to show and to remember the incident.
I can still count to 10
Neal in San Jose
While making 50 identical display stands, I needed to make many repetitious cuts on the table saw. I had cobbled together a quick sled for one particular cut, and after about 40 cuts, BLAM! My Sawstop fired! I determined I was unhurt, and then spent about 10 minutes trying to duplicate what I had done wrong. I wasn't unable to, and finally convinced myself that it must have been a false firing. I then started to take the blade with the fired brake assembly fused to it out of the saw. While doing that, I noticed a tiny drop of blood on the index finger on my right hand.
With that drop of blood as a guide, I was able to then duplicate what I had done to set off the Sawstop. I had simply let my right index finger drift over from it's corrrect position on the sled into the "line of fire". My brain had gone to sleep and had allowed me to make a mistake. I wasn't able to duplicate the mistake originally, because I "just knew" where my hands and fingers were.
I learned a couple of things. First, take breaks when doing repetitious work so my brain stays active. Second, make sure that sleds (and any other safety devices) are comfortable and don't allow important body parts to wander.
Ken Oakley-Sunny St. Cloud, Fla.
Two that standout in my memory are the time I shot a brad from an air nailer through the finger nail of the thumb of my left hand into a piece of 3/4" plywood. A little tug and my thumb was released from the board. The second was not watching as I worked on the bandsaw and running the index finger of my left hand, again, into the blade vertically cutting to the bone from finger tip to above the knuckle. I have had minor nicks and shavings to other fingers also, but still have ten fully functioning fingers. Lesson learned-Never put your finger where you wouldn't put your tongue
Steve Schoene
I've got a tip of my left index finger that can predict rain, the result of an attempt to joint a much too small piece of wood many years ago. Otherwise the most serious injury has been an occasional nick with a carving gouge that required a bandaid to avoid staining wood. Almost never while actually using the tool, but when picking one up or setting another down.
I was ripping a 4' piece of cherry wood. The waste side was slender and tapered. As I made the cut I saw the kerf drifting. I looked down and saw the fence was moving away from the blade. I had forgotten to lock it down. Before I could react a kickback occurred. The waste side of wood was propelled at my abdomen...a kickback. Without looking down I felt my abdomen and felt the wood sticking into me. Not even thinking, I pulled it out. I knew I was seriously injured. The result was emergency trauma surgery. The surgeon told me I was very lucky...1/2" more to the right and it would have severed my liver. The wood had gone in 5". I now have a lovely 3" scar to remind me of the following:
1. ALWAYS use a splitter whenever possible (mine was off at the time)
2. ALWAYS check your fence and make sure it is locked before making cuts.
I don't consider these as "tips"....these are "laws" in my shop now.
T.
Jim Dillon
Ellis,
I did the exact same thing as Ken did with the brad nailer. I was repairing a birdhouse(!), and the brad hit an internal nail and curved upward right through my thumb and nail. Now I really watch where my fingers are when using any nailer/stapler.
Have had two kickbacks both with small pieces of plywood. In both cases, the pieces were too small, and the leading edge moved away from the fence just a tad, but it was enough to catch the moving blade. Luckily, I wasn't hit but it shook me up. In both cases, I was in a hurry and at the end of a shop workday. Now I've altered my work habits and use a sled for the small stuff (or use the bandsaw).
Jim
Tim Greif - West of Chicago
I was freehand cutting on a RAS. By freehand, I mean that I was cutting an angle on a piece without swinging the arm to that angle. The RAS was set for a straight 90-deg cut and I was holding the piece with only one point against the fence and the edge closest to the blade was being held out front of the fence. The blade grabbed the piece and slammed it into the fence, unfortunately with my two left middle fingers ending up nicely between the piece and the fence. Let's just say it was the equivalent of smashing those two fingers with a hammer.
The skin had broken up pretty well so I taped them up. I have a very high tolerance for pain so I didn't seek any medical attention. But it did hurt a bunch. Next day, they were really black and blue. At the insistance of LOML, I went to an urgent care center where they x-rayed and pronounced the fingers broken. They pretty much insisted I see a hand surgeon since I had waited so long to come in.
Hand surgeon explained it like this. You basically did the equivalent of hitting your fingers awfully hard with a hammer, causing them to sort of explode. That's not the bad part. The bad part is that there is an opposite reaction where bacteria or other bad stuff can get sucked back into the open wound you just created. If I'd gone right to the doc and got it disinfected, no problem. But since I waited 24 hours, there was the possibility that the bones could become infected. Doc said we could do nothing and I might get lucky and no ill effects. Or, if not so lucky, I might lose the fingers due to bone infection if we did nothing. He recommended cutting the fingers open to disinfect all flesh and bone in the subject area. I gladly opted for the surgery.
I'm happy to report that I have no lingering problems with the fingers, although they were quite sensitive to cold for the first year. I also no longer do any type of freehand work on the RAS. Funny thing is, I'd done stuff like that for years on that saw. I'd had it for close to 25 years. You can never be too careful.
FredD
I can't relate any mutilation stories and I still have everything I was born with except Teeth and Hair , but a potentially dangerous situation with splinters has come up nearly every year for the last six or so.
About once a year or less , when I get a splinter regardless of the wood specie, a raised red hard lump forms which develops a white center.
This is the indicator to go see the Doc , who has seen so many of these on me that he knows without doimg a culture that it is Mersa type Staph and gives me Ciprofloxin , sometimes alternated with another drug , so I don't take to much of one.
Turns out that that Staph lives on my hands which I religiously wash and the splinter puncture carries the Staph into the wound , thankfully not always....
FredD
John Cole
I've learned that you need to go to the hospital right away if the cat bites you......no wait, that's a different board.
When setting up the tablesaw, make sure you don't park the car in direct line of fire of a kickback. The flying board missed me but did a bit of damage to the car door.
Paul Vander Woude
I was using a nice sharp 1/4 inch wood chisel to clean up some corners on a stopped dado. I finished up and pulled the part off of the vise setup on my workbench, when I noticed a little nub of wood left in the corner of the dado. Rather than re-clamping the part, I just held it in one hand and pushed the chisel into the corner of the dado with my other. Of course it slipped, and I stabbed myself in the left wrist, severing an artery. I spent the rest of the day in the emergency room, and had microsurgery to repair the artery. I spent more money in that one afternoon than I have ever spent on a lifetime of woodworking. I have a nice little Harry Potter shaped scar on my wrist to remind me of the following lessons:
ALWAYS use two hands on the chisel, and NEVER use a chisel on a part that isn't clamped in a vise.
As in all things . . .
steve mackay
DON'T GET COCKY ! Funny (yea, right !) thing this should be The One this month. I've been healing three fingers for the last month. #s 2, 3 & 4. Chewed the ends down to the bone. 27 stitches all told. Lucky, lucky, lucky everything is still there and there was a Combat Medic (fresh from Iraq) on duty at my ARMY hospital. THEY don't worry about "pretty" . . . just "right". And it IS looking great ! I had push stick, blade gaurd, fence, ear muffs, good light, safety glasses and gloves. I was not in a hurry nor distracted. Honestly, I've no idea how I got my hand in there. Still don't. The glove was nothing but a lint ball. How that kid got the skin to wrap back over the finger tips was true craftsmanship.
So, moral of the story and the most important point is that NO MATTER how safe you THINK you are DO NOT GET COCKY. ANY cutting tool is meant for cutting, and it can cut YOU. You can ALWAYS get hurt !
Bill White
Years ago, the old TS kickback. Stayed away from a TS for about 30 years while using a RAS. Yeah, I know. The RAS has such a bad rap for eating you alive, but no injuries from it.
Bought the first TS about 5 years ago, and I still watch it carefully. Full compliment of guard, splitter, ear muffs, eye wear, etc. So far-so good.
Bill
Kickback happens. I was "punched" once in the gut - now I stay clear of the line of fire. I also make sure that I have a FIRM grip on the work.
Non moving saw blades can also injure. The teeth are still sharp even when they aren't moving. Saw jaws are a GOOD invention.
Dave Paine
Ellis, happy to say I have not experienced any catastrophic events.
My shop is my garage. The closest call was replacing the springs on a garage door. I opened the door to ease tension on the spring, and then was trying to remove the spring on one side. I had not clamped the door. It started to drop and the spring caught my hand between the wire and the pulley. The wife was away and my mother-in-law was one story above, 40 ft away and partially deaf.
I was somehow able to pull back the door just enough to remove my hand and THEN clamped the door in the full open position.
Lesson learned was to better prepare for an operation.
My worst injury was not in the shop. I was helping a friend to install some Ipe decking. This required drilling the holes. I was walking across the joists and lost my footing. I reached with my right hand for a vertical post. Not a problem. I then followed with my left hand to steady the hold. The problem was my left hand had the drill and I managed to impale my right hand. The drill was not operating, but I managed to bury this into the flesh. I went home feeling rather foolish.
Lesson learned was to not walk on joists.
I try hard to clamp any object I need to plane or use a chisel. If I cannot clamp, I hold with one hand and have the plane or chisel to be in front of the hand.
I have not had kick-backs, so far thankfully, but I have experienced a board with internal stress trying to close on the blade. At the time I had a splitter which saved the day. The motor stalled and I was able to turn off. I now have a riving knife table saw. I would not want to use a table saw without splitter or riving knife.
Another close call was when I used the new saw with riving knife to cut pieces to make an outfeed table. One of the pieces was long and as it passed over the table, it tried to push the piece. I was able to control with the push stick, but this was scary.
I now have the outfeed table installed and can cut an 8 ft long piece with the overhang being less weight than the portion on the table saw + outfeed table.
Lesson learned. I would not want to use a table saw without an outfeed table.
Other accidents include the common problems with slotted screws. Too easily for a hand to slip and the screwdriver goes into the flesh of the other hand.
Lesson learned. Throw out slotted screws where possible.
I also have to admit to bashing thumb or fingers with a hammer.
Lesson learned. Use screws, or hold the nail with needle nose pliers.
George Colonel's Workshop-Havertown PA
Good Even ing Ellis,
I've had a couple incidents which were note worthy, each requiring a trip tho the ER. First was a jointer accident. It was a brand new tool which I demonstrated for one of my boys aend his friend. My son shouted a question over the noise of the tool as I was feding the stock thru the blades. I turned my head to answer. I saw the horror in his face as my finger wandered thru the blade amidst a puff of pink vapor. It cut off my finger tip, and now that finger is slightly shorter than its twin on the other hand.
The next incident occurred on my lathe. I was in process of making a bowl when my left wrist came in contact with the sharp rim of the bowl.It sliced thru my wrist in an instant, and was pretty deep. At the ER, the attending doctor showed me my sheathed tendon, remarking that just a little deeped cut would have severed it. As it was, she stitched it up good as new.
Lack of awareness and concentration and distraction were the causes.
George
Lee Schierer McKean, PA
About 18 years ago I was making a door for a cabinet for a friend. I needed to cut some blind rabbets in the four rails. I set up the dado blade raised it to the needed height, adjusted the fence to give me the right width, marked my start and stop points, did a test cut on a piece of scrap by pushing it through the blade (non-blind cut). So I was ready to make the actual pieces. I started up the saw and carefully set the first piece in place and lowered it down onto the moving blade. Completed piece # 1 no problem. Turned the saw off, removed the piece, started the saw up for cut #2. As I lowered the second piece down onto the moving blade, it grabbed a bit, but I was able to control it and make the cut. As the alarm bells were ringing in my head, I reset the saw for cut #3. This time as I lowered the piece onto the saw, I had a really good grip just in case it grabbed again. It did grab and it yanked the piece backwards across the blade. My left hand which was behind the blade, suddenly had nothing it was pushing against and it came back through teh dado blade, chewing up my little finger.
I was fortunate. 25 stitches later, my finger was patched up and I had a huge gauze wrapped finger for the next 3 weeks. I had no tendon or nerve damage. I took a lot of ribbing at my new job over the incident where part of my job was safety supervisor.
What I learned was that you always raise the blade into the work, never set work down onto a moving blade. I also learned that if you are going to make blind cuts by raising the blade into the wood, that you should have a stop block behind the piece to preclude any chance of kick back.
Lee
Tom Pilsbury (Chicago)
The most important thing I've learned here at WC is this one sentence I read years ago:
If it slips....where will it go?
I don't remember who wrote that, but I Thank You every time I use a hand or power tool. I even printed it out in large letters and added a picture of a hand with a severed finger and hung it on the wall. (Yeah, it might be gruesome but it's a good reminder of what could happen and it keeps me alert)
So far other than a few splinters, scratches and scrapes I haven't had any major accidents.
Knock wood. :)
FredD
The process mentally is kinda like the old five inch /38 deck gun on a hang fire.
You always wait thirty minutes before opening the breech ;-))
FredD
I use that too Tom !
Don Orr
It has saved me from being stupid many times. I have trained myself to say it in my head before I do most anything involving any cutting action. I also try to pass it on whenever I can. Thanks to whomever originally posted that!
I have also been lucky (read careful) in that I have only had the usual knick, scrape, splinter, minor cut(fixed with bandaid or CA glue). I had a great shop teacher in Jr High School-Mr. Grubel. Safety really WAS first. Plus all I have learned here on WC has been invaluable to keeping all my parts intact.
Worst tool related injury is similar to one above. Many years ago I drove a rusty, dull #2 Phillips screwdriver nearly through my left palm when it slipped. Back to " Where will it go if it slips?" Hadn't learned that mantra yet.
A question Steve, gloves?
Gary Camp Bend, Oregon
Not to try and Hijack the thread but it is safety we are talking about. I was taught never to wear gloves around saws or other roatating devices. The glove isn't always where the hand is and if the glove is caught so is the hand. What is your reason for gloves? What do others think?
Thanks
glc
Heal up quick Steve...
John in NM
It's happened to the best of us, glad it wasn't worse and you got stitched back up.
I learned the same
John in NM
No gloves, no loose clothing.
Never used to . . .
steve mackay
wear gloves for just that reason. Dad is / was a tool & die maker and always told me the same thing. I finaly tried these close fitting "mechanics" gloves though. Unlike traditional leather / work gloves these fit very close and actualy work well even for my miniature work. I guess "sensitive" might be the word. The supervisor on duty in my ARMY ER said he could tell mine was from a table saw. He had had TS and circular saw injuries within the last week. He can tell the difference. He also said the gloves probably limityed my damage. He is of the opinion that you'll feel something grab, react and pull back sooner. Who knows ? I DID stop and get a new pair last week though. Can't get them on now but they're ready.
Danke !
steve mackay
