Porch Railing questions
Working on stoop/porch railings for the house Ive been working on for my son.
Went to Home Depot to look at what they have. They have a system of vinyl that includes square vinyl sleeves that appear to fit over 4x4 posts and then vinyl rails and posts caps etc.
They also had steel inserts that appeared to be designed for you to install them first and then put the sleeve over them. They were about $30. Treated 4x4's are about $3. Are the steel inserts significantly better than plain old 4x4's?
My original plan was to install hot dipped galvanized threaded rods vertically and drill a hole in the bottom of the 4x4 and epoxy it over the the rods. I have the threaded rods in place, but could ignore them if the other system is better.
There are two brick stoops I am working on. Can somebody clue me in on what you think is the best way to do this?
