What size holes for wine rack
OneDayJD
I'm building a kitchen island/butcher block table. Under the table top I am putting a wine rack between the legs. Basically going to take 1x4s (or 1x6s?) and use a drill press to cut holes down the board, then rip it in half to have the semicircle "cradles" for the bottles. My question is: for a standard wine rack like this, what size hole saw bit should I use for the butt end of the bottle (back) and for the neck (front) of the bottle? Also, is there a rule of thumb as to how much I should space the front and back boards from each other? Thanks for any advice!
Re: What size holes for wine rack
Moses Yoder
Moses Yoder
The front hole should be 1-3/8" diameter, the back hole 4" diameter, and there should be 7" between the boards.
I used 3-1/2 for the body and 1-1/2 for the neck with the two racks spaced a bit less than 8" apart. I also set the bottom of each notch level with each other so that the corks stay wet with the bottles canted down. Up to you whether you want the necks or the butts facing out. Center-to-center spacing depends on how much width you have to work with but I think 4" was the minimum.
Wine bottles vary in shape. Red wines are often in shorter wider bottles and whites are often in longer thinner bottles. Then there are the bubblies.....
To play it safe the cradles don't have to be complete semi circles. I use use curved cradles that are about 3" wide and about 1 1/2" for the necks. In both cases I do not used full semi circles so that wide bottles don't get pinched.
Tom
Moses Yoder
Re: P.S.
Moses Yoder
If you use the dimensions I gave you and make semi circles as Tom mentions your wine bottles (average size) will fit like this.
Scott in Montana
Using only partial semi-circles is important since Burgandy bottles and some Pinot bottles are larger in their body diameter. Bordeaux bottles have been regulated in size for the last 30+ years and most cab bottles follow suite.
Scott in Montana
...and don't forget Champagne bottles.
Scott in Montana
Re: What size holes for wine rack *LINK*
John McGaw
Even 'standard' wine bottles are rather non-standard even presuming that you won't be racking magnums and jeroboams. The style of rack you describe is probably less accommodating than others such as front-to-back slats.
This chart will give you an idea of what a commercial maker of wine racks thinks are common bottle sizes.
Commercial Wine Rack
OneDayJD
Fantastic info! I really appreciate all the info. I will still probably do semi circles. Mainly due to the fact that I don't have a router or band saw or anything to do cradles. In fact, I don't even have a drill press, I'm either getting one from a pawn shop, or my contractor neighbor is going to let me use his. I just got into woodworking within the last year. And being a broke third-year law student, about all I can afford is a jigsaw and a chop saw. I would love to do something that would hold magnums as well as standard bottle sizes. But again, I'm just going to have to make it work with what I've got.
Jim Dillon
Welcome to Woodcentral! The great thing about woodworking as a hobby is that you can make really useful things for around the house, apartment, etc. Keep us posted on how you make out with the wine rack. Speaking just for myself, my wine never seems to get further than the cardboard box it came in, but that is a whole other story :) .
Jim
John McGaw
If it only lasts that long then it means that you don't buy nearly enough of it. ;) I usually feel uneasy unless I have at least 4 - 5 cases on the rack downstairs.
Jim Dillon
John,
LOL! I really do try my best to keep the local wine merchant solvent in this tough economy, but one person can only do (or drink) so much!
Jim
Moses Yoder
Moses Yoder
All you have to do to make semi circles is drill a 4" hole in a 5-1/2" or 6" wide bore then rip off each side at about 1-1/2" - 1-3/4". Mark it out before doing any cutting you will regret. The front hole can be cut the same way, just drill a smaller hole in a 3" or so board then rip it down to 1-1/4" wide or so.
Jesper, Denmark
Re: I guess i am stumped....
Jesper, Denmark
I store wine bottles on a plain shelf built next to the upper cabinets in the kitchen. The bottles just lie on the shelf on top of each other. No need for a rack, which takes up space.
Granted, if you want a bottle that is in the bottom layer, you have to be a little careful, but so what?
