OT - Verizon USB modem
Ray - Middletown, IN
Anyone using the Verizon USB modem. I have one of the newer 4G models and the thing will not keep a connection most of the time. Some days it works ok and others it will not stay connected more than a few seconds to a few minutes. I have the LG VL600 and the old 3g model I had was a Pantech that worked passable. I do live in a fringe area but this is getting ridiculous. Any ideas?
Thanks,
Ray
2 connection just to write this
Re: OT - Verizon USB modem
Yup it is the 4G
Dustmaker Mike
I do not have one of the Wireless modems but if I understand it correctly the 4G standard has not beed approved yet. Which means each company Sprint ATT and Verizion all claim they are 4G and each one measures it in a different way. Now to your question 4G is alot picker then the 3G ever was, until the inferstructure is all in place it will stay that way. I would call Verizion on the bad days and let them know so maybe they will upgrade the towers near you sooner.
Dale Stansbery
Ray, I've been using the Pantech for almost 2 years. I also am in a fringe area. My service has always been slow, but much better than dial up until this winter. My signal increases in strength in the winter (no leaves I guess) but even with a stronger signal, this winter my connection has been very erratic, dropping out frequently. Verizon's tech support tells me that I get my signal from an old Alltel tower which Verizon bought, and they aren't upgrading it.
They also told me that it's going to be a while before the 4G upgrades reach everywhere else.
It looks like my best option is change to a satellite ISP.
If you aren't using an external Yagi antenna, you can pick up an additional 10-13 Db signa with one. That equated to about a 10 point increase in my RSSI. If you open Verizon access manager, hit "control d", use the password "diagvzw" and run the field test, you can see your RSSI level, and align your antenna to maximize signal strength.
I had the Pantech
and it worked similar to yours, slow but slightly better than dial up. In January I got the new 4g LG model and the first 10 days were miserable but then it settled down and worked about as well as the Pantech but in the last week it has started dropping every minute or two and gives a hardware error message for several times before connecting. They sent out a software upgrade recently,,, Hmmmm. I couldn't recommend Verizon to anyone looking for a cell modem. I'm seriously thinking of buying out the contract and going elsewhere.
Ray
