Question on making a chess board
wilbur
I've been making a chess board, and I am close to the point where I'd like a reality check on my plan. What I've done so far is cut maple and walnut veneer strips slightly more than 1/16" thick, and glue them in an alternating pattern onto a piece of MDF. I plan to cut the MDF and veneers across the stripes, and then rotate every other piece to make the checkerboard pattern. Then I'll add an outside frame.
What I want to check on is [1] whether I should level the veneers with a plane or card scraper now before cutting the board into strips, or wait until after I've done the cutting/flipping/regluing, and (b) whether putting blue tape down on the veneered side over where the saw cuts will be is enough to prevent chip out, or if there are other chip out prevention measures I can take.
Thanks!
Re: Question on making a chess board
Dave Paine
Sorry you have got this far.
I made a chess board from solid wood, oak and walnut, cut 8 strips and then flipped similar to how you describe.
After flipping the dimensions were not quite level.
I later read an article which mentioned to make the slab 9 strips wide, then you just need to "move" over 1 colour but not flip. Would have made for less time correcting the dimensions.
I would flip and then flatten as needed. Fingers crossed not too much correction is needed.
Sanding vs scraping depends on whether the grain all runs in the same direction. If all in the same direction you can scrap with the grain.
If some pieces are not in the same grain direction, I recommend sanding. Scraping can result in tearout. Experienced this just a few weeks ago.
Unless you are committed to hand techniques
Bruce, a MN Galoot
I would sand it. I've made three, and no matter how carefully you think you've cut the pieces, there are always slight variations. On the boards I made, I alternated the grain orientations. On the first two, the squares touch each other and on the third (following an idea in Woodsmith), there is a gap between each piece the thickness of a piece of paper. In all three cases, I leveled the top by sanding. On the third board, the squares are 1/8" thick, so there is a need to compensate for seasonal wood movement.
George Colonel's Workshop-Havertown PA
Good Evening Wilbur,
Shop Shot 938 shows the 10 chess sets I recently completed. I cut the veneer into strips and placed it on a slab of granite for flatness. I used ordinary carpenters' glue to bond the edges together. Using blue tape as a clamp to keep the oriented strips tight together worked great in every board. Once the glue had hardened, I removed the tape, and then glued the fabricated board to the plywood substrate. Weighted down the board with all things flat and heavy.
I did not bother with gluing up a 9 piece checkered strip and then trimming. All my strips were 8 squares long. I sanded the entire unit to level,once border and perimeter trim were done.
George
