Thats Mine!
Ken Bellock (Houston, TX)
I wrote that app last fall while I was laid off for three months. It was a good project to learn Java on and a good intro to the Android Market. Seeing it mentioned here on woodcentral is more than I ever expected though. It makes me very proud of the little app, as I have been hanging out here for a long time and have a great respect for the opinions and wisdom that comes out of this forum.
I have received good reviews on it, and it will pass 5,000 downloads of the free version today, but it, like everything else I have made, has flaws and I am always annoyed by knowing those flaws are there.
It works by reading two sensors in Android devices. The g sensor, which gives me a vector pointing straight down, and the magnetic sensor which points to magnetic north. The problem is that the magnetic sensor in most devices is horribly inaccurate, and also doesn't tend to work very well around metal.
For measurements where your reference is close to level, like a table saw blade setting, it works fantastically well, because the measurement is almost entirely based off the g sensor.
For measurements like wall angles for crown molding it can be off by several degrees. That's because its relying too heavily on that crappy magnetic sensor, and corners usually have that metal drywall corner thing in there, or nails, which also mess with the magnetic sensor.
It also will not work in a free fall state. Though I do not see many uses for sky divers... it still bugs me that it will not work for a couple seconds out of the plane...
So if you are intending to use it like a tiltbox or wixey angle finder it should work very well for you. And it will only continue to get better as newer devices come out with better sensors. And it has lots of tweakable/customizable features!
