THE WOODRAT IS BACK!
Haunched Tenon
Haunched Tenon
Haunched Tenon
Greg Muller
I am making a Library Stand useing Mortise and tenon joints. Do I need to use a haunched tenon on the top strectcher if it is even with the top of the leg. Also what is the purpose of a haunched tenon.
Re: Haunched Tenon
Re: Haunched Tenon
Jesse Cloud
Haunched tenons offer some additional resistance to twisting on a leg, often a problem with tables when they are moved by pushing rather than lifting. They are a good idea, but by no means mandatory.
Re: Haunched Tenon
Darrell in Oakville
Re: Haunched Tenon
Darrell in Oakville
Greg asks
The haunch is there to fill in the end of the groove in frame and panel work. Before the advent or power equipment the standard tool for grooving was a plow plane. These planes were not designed to do stopped work, so your groove went all the way out the ends of your stock. This necessitates an extra bit on the end of the tenon piece to fill up the gap. I don't think it has anything to do with strength, it was just the way the joint worked.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
Re: Haunched Tenon
Re: Haunched Tenon
Darrell had a good answer if that is what you are referring to as a haunched Tenon. I can't think why you would need one as a filer on a table leg. I'm not sure exactly what your application is so I can't answer that part of your question. Another thought is that a haunched tenon would be something like the rail of a table and it was 3/4" thick by four inches wide. You could cut tenons on the ends of these that were full width and half inch thick. Then there would be a shoulder on each side of 1/8 inch if the tenon were centered on the rail and the tenon would be flush top and bottom. This would mean that the mortice in the leg would be open at the top and four inches wide also. Another approach would be to cut a three inch wide tenon the end of the same four inch rail and leave a half inch shoulder (haunch?) top and bottom. This way the mortise would be half inch down for the top of the post and three inches wide.
If this is what you are calling a haunched tenon then I think it would be stronger than the full width one because the shoulder or haunches top and bottom would act like fulcrums when the table is pushed around. Instead of trying to bend the joint, the forces would be trying to extract the tenon out of the mortise. I have no scientific data but I think it will ressit extraction better than bending.
If this is not what you meant by a haunched tenon, forgive my incoherent babbling.
Re: Haunched Tenon
Re: Haunched Tenon
Sgian Dubh
One place to use a haunch to good effect is where, as you describe it, show faces of both the tenoned and morticed member are flush. The haunch helps prevent the show face(s) of the tenoned part becoming misaligned with the face(s) of the mortised part. This can occur when the tenoned part cups: the haunch buried in its shallow mortice resists the cupping.
Two main forms of haunch exist, there is the square haunch, traditionally used to fill the groove worked in frame and panel constructions, eg, doors-- but it can be used at table rail (apron in US speak) and leg type connections, etc. The second type is the sloping or secret haunch (see below) used where you don't wish to reveal the fact there is a haunch in the joint.
The sloping or secret haunch is less effective at resisting cupping of the tenoned part than the square haunch. Sloping or secret haunches are usually only used at outside corners of frameworks. Notice in the sketch below that the tenon takes up only about 2/3 of the rail's width. This is so that the end of the mortice is not too near the top of the leg which would lead to weak short grain, and likely rapid failure if the joint experiences racking stress, eg, a table dragged across a floor, etc.
Where the face of the rail (tenoned) is inset from the face of the leg or stile (morticed) there is usually little need for a haunch to prevent cupping of the rail-- and it's more work for very little gain in strength or usefulness. Slainte.
Photobucket
