Air Hose Reel Retrofit
Thomas Norton
I bought a HF air hose reel and had a question. In the shop I really like to use 1/4" hose as it is easier to move around.
So here is my question. Do you think I could take the air reel that has 3/8" hose and change the hose over to 1/4"? I know iwould need some different fittings where it connects on the reel. But this would allow me to "store" all of my hose instead of connecting my 1/4" to the end of the 3/8".
Thanks!
Re: Air Hose Reel Retrofit
Dave Paine
Yes, as you stated, you may just need an adapter. Depends on the fitting at the end of the 1/4in hose.
The potential issue is whether all 1/4in hose will have too much pressure drop for the tool.
Some tools need minimum pressure and minimum airflow rate. You can easily get the pressure, but the hose diameter and length will determine how much airflow you get for a given pressure. You may need to run the hose at higher pressure to compensate.
Jim DeLaney, Austintown, Ohio
If it's the 'spring-loaded' version, then NO, it won't work.
The spring is designed to be wound tight when the 25 feet of hose (of whatever diameter) is pulled out.
If you try to put a longer hose on the reel it'll just stop when it hits its 25 foot limit - or else the spring will break, giving you a non-retractable reel.
Re: Air Hose Reel Retrofit *LINK*
Alan in Little Washington (NC)
I replaced the 25' 3/8" rubber hose that came with the ReelCraft reel I got on Ebay, with 35' of 3/8" Flexeel polyurethane super flexible hose by Coilhose. It works great- there was plenty of extra spring to wind it up.
I initially had one problem, the hose would not slip on itself and so sometimes would wind up in one spot and jam the reel before all the hose was retracted. Once it got a little dirty and dusty, this problem pretty much went away.
Amazon carries Flexeel but Coilhose carries the hose, nice reusable fittings and strain reliefs, etc. for it so you can make up your own custom hoses.
Coilhose
Another option for flexible hose *LINK*
Dave Paine
If you have a spring constraint and want flexible and light weight 3/8in hose, take a look at this product "Flexzilla" brand.
I do not yet have a hose reel, so doing the manual coiling.
I purchased a 25 ft section. Lighter and more flexible than the standard hoses.
I do not feel I am fighting with this hose.
http://www.eagleamerica.com/product/v480-2025/maintenance
