observations on chair repair & M&T joints
DizD
Recently completed a repair on a mahagony chippendale style armchair used in an office for over 25 years. Stretchers were loose and one had fallen out. During disassembly I noticed the tenons cheeks showed very little signs of glue - they were mostly bare wood. Mortices had rounded ends and tenons were square- sized to fit the flat section of the mortice. There was glue in the rounded ends of the mortice and in the bottom, and most of the tenons had wood failure on the ends where the glue was. Apparently these were assembled with the glue pellet system where a pellet was dropped into the mortice and when the tenon was seated, the pellet broke and forced glue into the joint. Because of the large voids, most of the glue never made it to the cheeks of the tenons. There was a split above the mortice at top of one leg, and that was repaired before glueing tenons and reassembling.
I found it interesting that the chair held together as long as it did considering the limited amount of wood/glue surface area. This would be the ultimate in reversability - no glue in the joints to get in the way of repairs!
