Some philosophical thoughts on finishing
Bill Tindall
It seems that the most reoccurring problem that gets addressed here involves finishing. During this last round it struck me that these problems usually involve some product that isn't used by professionals, or a product used in a novel way. People are striving for a "professional looking finish" using material or techniques different from what professionals use, or even different from directions on the can.
Perhaps the most reliable, and certainly the quickest, route to a "professional looking finish" is to use materials and techniques that professionals commonly use.
The impediments to using professional materials and techniques are, in most cases not great, except for shellac. Flexner was bold enough to title his recent article in Popular Woodwlrking "Shellac: A Challenging Finish". I agree, but that is another discussion topic.
By far the most common professional finishes are lacquer and conversion varnish, depending on the application. These products are readily available any anywhere in the US. Their application requires a small air compressor and a spray gun but these are not huge capital purchases compared to table saws, for example. And, an air compressor is a handy multi-tasker around the shop. (note: conventional spray guns are significantly easier to learn to use so if you don't require HVLP don't buy it).
Learning to spray many object shapes is not difficult, flat being the easiest. I have a daughter that likes me to build her stuff and when she is around I get her to finish it. With a 5 min lesson she was able to spray simple objects with lacquer. (note: solvent based lacquer is formulated to be easy to spray) Chairs require more experience.
The bottom line is if you can justify a table saw over a hand saw to speed up making stuff, you can consider buying a spray gun over a brush to speed up finishing.
