Problems with General Finishes HP WB Poly
Bart Goldberg
I recommended to my brother to use the General Finishes HP Water based poly to refinish his kitchen bar. He applied about 5 coats using a foam brush. The finish looked great when done. However, a day later when he got a drop of water on the finish, it left marks in the finish. Not sure what is going on, cause this product should be very resistant to moisture. Any ideas whats wrong??
P.. He did sand the existing finish (Bartley's gel vanish that is several years old) with 600 grit before applying the General Finishes product.
Thanks
Bart
