hole saws
woodenleg
Does anyone know how to sharpen hole saws? I have 5 or 6 that I use all the time and I really don't want to buy new ones. Also is there a certain to sharpen for UHMW? Thanks, Dave
hole saws
woodenleg
Re: hole saws
Keith Newton----Little Rock, Arkansas
I sharpen them just by holding them freehand to a 1/4" white grinding wheel. I usually grind two of every three teeth off, so it will have a large enough gullet for the chips. And on even larger ones, I may take 4 of every 5.
Another improvement, is to have zero hook. Those things come with a little hook which is why they snag so badly. So just try to end up with alternate bevel the face parallel to the axis of rotation.
Do this, and they will drill about five times faster than when new.
Re: hole saws
Phil Joines
Try the files used to sharpen hand saws. The size would depend on the tooth size, maybe a 7" slim. They are still available from places like Woodcraft or Tools for Working Wood.
Re: hole saws
Keith Newton
Hole-saws have a bi-metal blade, and the teeth will be as hard as a file, so it would probably ruin anything other than a diamond file.
