O.T. Truck Repair Paint Issue
Stuart Johnson
A little over a year ago I had the back panels on my F-150 repaired. They did a great job in fixing the truck and all was fine until a week ago. When washing the truck I notice the paint on one of the repaired parts has bubbled. I don't know how long it has been this way but I think I would have noticed it if it hadn't started fairly recent. I'm going to take it back to them but as the repairs were done over a year ago I don't know how or if they will do anything. Prior to going in I would like some idea on what caused the problem. The attached photo shows what it is like.
Re: O.T. Truck Repair Paint Issue
Bob Burnet (NW FL)
The line at the top looks to be very straight. May want to look at the door on the other side before you go back to the paint shop. Any chance that is the way it comes from the factory?
Bob
Nat Robison
If this is the bottom of a door near the rocker, it could be "gravel guard" or something similar that the shop sprayed......a thicker-than-paint layer that the shop sprays in these areas to help ward off stone nicks and chips. Obviously, if you know this wasn't there after the repair, it may be rust. Either way, it deserves a trip to the shop.
Stuart Johnson
My first thought was rust and that might be the answer but I'm a little doubtful. It is such a nice straight line which makes me think they might not have prepared the surface properly prior to painting. I haven't picked at the area but thumping it seems solid. When I first saw it I did go over and take a look at the other sided thinking it might be some sort of protective coating.
I'll take it into the shop and see what they say.
Was it an insurance job?
Grant in Iowa
If it was an insurance funded repair, then your insurance company will fund the re-repair of it.
A friend of ours had a car with metallic tan paint that was involved in an accident. It looked good when it was first repaired, but the paint faded quicker than the original paint and the fender stuck out like a sore thumb in about 4 years. His insurance company repaired it a second time (or at least arranged the repair with the original body shop.
I believe this was State Farm.
FWIW,
Grant in Iowa
Re: O.T. Truck Repair Paint _All is well
Stuart Johnson
I took the truck into the repair shop and when the adjuster came out to take a look he just smiled and shook his head. It is rock guard. He said they put it on heavier than Ford and wished that was pointed out when the repair inspection was done. He also told me that had there been a problem it would have been fixed with no additional charge or paperwork. That doesn't surprise me as they have been in business for 30+ years and just moved to a new updated building.
