We value your privacy.
I think I stalled my bandsaw one time too many while resawing and burned up the start capacitor.
The saw won't start on its own but if I give the wheel a spin it will spin right up and run just fine.
Assuming I am right in the diagnosis, where would I get a starter/capacitor for this motor? The nearest motor shop to me is over 1/2 hour away and I like to fix things myself anyway rather than pay someone else. Anyone have a source online somewhere I could get motor parts?
BTW, this is a Jet JWBS-14CS closed stand bandsaw with the 1 hp motor.
In the end of the motor are a set of contacts that bring in the start circuit when the motor is stopped, then open as it comes up to speed. The contacts get dirty and do not make contact which gives your exact symptoms. Try blowing out the motor and see if that helps. If not, you can take the end off the motor and you will see the contacts and the spring weights that operate them. Try cleaning everything up and lubing it then see if that helps.
What Don said. I had the same problem- the contacts in my old DC motor were pitted real bad and eventually it wouldn't start. A little emery board on the contacts fixed it.
take the cap off and look at the end of it where the spade lug's are . Ifthe end buldge's a little it probly is open. May be open any way get the value of the cap and call the motor place. If they have one go and get it. That will be the easy way out. I would bet on the cap open . I belive if the contact's were bad it wouldn't run. Their are start and run contact's on the plate. The start contact's point's get the most ark to start. than the run contact's take over. If you take the plate off make sure that the sleve slides real easy. that moves the contact's . good luck a easy fix
They run just fine if the contacts are bad. Just need help to get going. The motor on my bandsaw is open frame and I have this happen every once in awhile. A good blowing out usually fixes it. A couple of times I have had to take it apart to clean the contacts.
There is usually only one set of contacts that need to be closed for start. The start winding and start cap are in parallel with the run winding. The switch drops them out when the motor reaches ~ 3/4 speed. The run windings are relatively short and heavy, the start is relatively long and very thin. Length yields magnetism power and heavier guage provides ability to take heat caused by load. Start windings drop out quickly to prevent melting their insulation. The cap gives a little extra kick for starting. If dirty switch keeps the cap in too long, the cap's solution boils which breaks down its thin insulation. The lite brown wax plug between the caps terminals will usually be gone or blown apart if it is bad. Run caps (oval metal usually) will swell and be mis-shapened. If the cap is bad, THERE IS A REASON. Cure the problem or your new cap will quickly fail
