REAL MILK PAINT
Gluing Brick Question...Epoxy?
Several of the bricks have come off the corners of the stoops at the house I have been working on for my son. In the past I have told people to glue them back on with epoxy. The advantage is that if the old mortar is still there and the brick fits exactly, you can make a nearly invisible repair and don't have to worry with matching the mortar.
So, anybody got a good reason why this is a bad idea?
And, if its a good idea, how dry do the bricks have to be? It rained last night.
Re: Gluing Brick Question...Epoxy?
Google epoxy brick repair
Nat Robison
I just did and one link suggest buying the epoxy from a contractor's supply house, not HD or Lowe's.
This link also stated that in almost all scenarios, the environment must be dry.
Re: Gluing Brick Question...Epoxy? *LINK*
Keith Newton----Little Rock, Arkansas
Thickened epoxy will certainly work. I have even thickened it with dry sand topping mix. However, if there isn't much overhang, you might be able to use something like liquid nails.
As for moisture, I wouldn't work it wet, but you should be able to use a heat gun to dry it enough quickly.
During cold weather, I usually mix in a solo cup, tilted with the hot water flowing over the bottom half of the cup, while I stir it. Last month, I spilled a couple of drops in my sink, which went through the flowing water, then stuck to the sink. So the water doesn't dilute the epoxy, but it may keep it from penetrating the surface of the brick, and hinder the mechanical grip that it needs.
The source that I use, does sell one specifically for under water.
http://www.fgci.com/
Joseph Mulherin
Barry, you ever heard of hydraulic cement? they use it underwater to fix pipes and other leaks and it sets up very well even under full water environment...could even patch a boat if necessary. I would chisel out a little of the existing mortar and use the hydraulic cement in a small cup...because it does setup rather quick...and use that to fill in the mortar taken out and it will look like the original mortar too.
FredD
That suggestion works fine,but you need to know that Hydraulic Cement expands , hence the name.
I would use it before Epoxy or any glue substance.
Also use it to set new metal dowels in the Stoop.
FredD
George Koch
Barry, In the past I have also used thinset cement successfully for these applications. George
Joseph Mulherin
I agree with using thinset. Just check into the setting time because they are much different fepending on the mixtures of the ingredients....45minutes would be ok in opinion...gives you time to set in place and smooth out the overflows. Bracing is also very important .
Jim DeLaney, Austintown, Ohio
Re: Gluing Brick Question...PL Premium
I put some of my loose sidewalk bricks back down with PL Premium. That was three years ago, and not a one of them has come loose.
