chair repair
chair repair
chair repair
Bruce, a MN Galoot
I'm fixing up a basket case chair for a friend. Every joint on the thing has to be re-done. The seat rails are doweled into the legs, and a couple are broke off, so since there is enough wood I'm routing out the dowels and replacing them with floating tenons. That's pretty straightforward.
The question I have is about the stretchers. They are doweled as well, but there's not enough wood to drill them out and start from scratch. Besides, the holes on the legs have been glue and re-glued, so they need to be scraped out, and maybe drilled before I get to useful, clean wood.
I plan to wrap the dowel ends on the stretchers with veneer and let the glue set up before final fitting. Is paper a valid substitute for wood veneer to wrap the dowel ends?
Thanks.
Re: chair repair
Re: chair repair
Jesse Cloud
I've never tried to use paper in this application before. I would be a little wary as I have frequently used paper between two pieces of wood to make a temporary glueup. That glueup can be broken easily with a few taps of a mallet. The paper always gives and can easily be scraped off.
Veneer can be softened with a glycerin solution (available at Rockler) so that it bends pretty well.
Just my two cents, hope someone with direct experience will chime in (and hopefully prove me wrong ;) ).
Re: chair repair
Re: chair repair
Paul Leuba
Faced recently with a similar problem, it turned out for me that the best approach was to turn a couple new stretchers with larger tenons that could be customed fit to the oversize holes.
Paul in Hunt Valley, MD
Re: chair repair
Re: chair repair
mdclor
Bruce,
I think I would drill out the mortises with a standard size drill bit, then glue in a short piece of dowel and let the glue dry. Finally drill dowels so the tenon fits tightly and glue the tenon into the dowel. This is similar to your idea, but I think it would be easier than messing with wrapping veneer around the ends of the tenons.
Disclaimer: I have never done this, but I did stay in a Holiday Inn last night. :D
HTH and its worth every cent you paid for it!
Merle
Re: chair repair
Re: chair repair
DizD
You might consider "plugging" the hole with new wood. Drill the hole out to slightly larger size and glue in a plug then drill new hole for the dowel
Re: chair repair
Re: chair repair
George Colonel's Workshop-Havertown PA
Good Afternoon Bruce
I used to do that kind of repair frequently. I would replace the stretchers rather than wrap them. I'd drill out the legs to clean wood, and turn the stretchers to fit. Clamp securely after alignment and be sure all legs make solid contact with the platform.
I've had success wrapping tenon ends with veneer, provided good contact. Have not tried paper oer sewing thread.
George
