So, who has the best idea? - Grinder dust ........
Jesper, Denmark
Jesper, Denmark
I have a Baldor slow speed grinder, mostly used for sharpening turning tools, but pose the question to what might be a wider audience:
It makes a wholy mess, particularly when truing the wheels. I am loath to connect it to the dust collector, as I see at least a theoretical possibility of sparks reaching the bnag of chips in the collector.
My only thought so far is a cheap wet vacuum cleaner, dedicated to the grinder, and starting with the grionder. One could leave some water in the bottom and still use the filter bag, as it will mostlikely never need emptying.
Someone must have solved this problem in an elegant and affective way, right???
Re: So, who has the best idea? - Grinder dust ........
Jim in Burlington Ont.
Jeg bruger en Dust Collector
Jim in River Oaks, Ont.
Jeg har en sp�nsamlerport i n�rheden af min langsomme hastighed kv�rn, jeg bruger det altid, n�r slibevaerktoej, dette holder omr�det rent for st�v og sundt for mig. Jeg h�ber, at min dansk er acceptabel. Jeg holder samling havnen v�k, s� gnister ikke er farlige
V�r forsigtig,
Jim
Go with the vac...
John in NM
Seems simple, effective, and relatively cheap compared to a dedicated dust collector. Though I've not done the math, I would guess that a vac would also be better suited to the small ports on a grinder too. Downside to a vac is that they wear out much faster than a dust collector. Pulling a lot of metal dust and AlOx grit, maybe the DC would wear out fast too though. Bearing behind the impeller will likely be the first thing to fail in either situation.
Jesper, Denmark
Re: Jeg bruger en Dust Collector
Jesper, Denmark
Well Googled, Jim,
It mixes up the two genders and uses different genders referring to the same noun. Port turned out to become "harbour", but all in all quite understandable, although a little like the language spoken by our Balkan immigrants - a version often used by stand-up comics here.
Thank you my friend!
Exactly what I'm planning
I purchased the smallest shop vac that Lowes had. I am going to build a PVC collector to run off the back of the dust ports on my grinder. I will connect this to the small shop vac that is dedicated to this purpose. Well actually I use it to vacuum up the chips from my metal lathe also so it will need to be easily removable. I'm not really concerned about the sparks but will monitor it closely for the first few uses to see if there are any burn marks in the container.
I used to sharpen on a 3 1/2" belt sander layed on it's back. It worked great but I forgot to remove the fiber bag used as a dust collector. It did burn small holes in the bag but that was only inches away from the grinding source. Even then it didn't set the bag on fire.
Jesper, Denmark
Jesper, Denmark
You are most welome, Jim.
Humorous and challenging posts are most welcome.
Re: what if
frank ashmore
you ran a pipe from the intake on the canister inside turn it 90* to within an 1" of the bottom.Then put 3" of water.All of the dust would have to go through the water like a water pipe.I had an old rainbow vac. a long time ago and that's how that thing worked.Did'nt even have a filter on the exhaust.
Jesper, Denmark
Re:Thanks  guys.................
Jesper, Denmark
Cheap and cheerful dedicated vacuum it will be.
I have one that has been usd all winter for mopping up melted snow in the garage. It has a stainless canister and cost $50.
