We value your privacy.
does anyone know of a power pill crusher that would survive crushing about 600+, 500mg pills?
We have used a Braun mini coffee grinder with success in the past but this morning it died.
Horse has a little over 600 of these pills to take between now and the end of the month. The drill is, crush em to powder and put em in his feed twice a day. At 20 pills per feed now and on a decreasing qty over the next 3-4 weeks)
I suspect that, with that quantity to process, one of the mini coffee/spice grinders might be the cheapest way to go. They are about the worst thing imaginable for actually grinding coffee but they are pretty good at turning lots of other things to dust. There is a Bodum unit on sale at Amazon for $10 right now.
But before you go to that trouble, have you disassembled the existing one and checked the brushes and springs and commutator? That would be what normally goes bad in a high-speed universal motor and that is what your grinder probably uses. Sometimes it just takes a bit of fiddling and cleaning to set things right.
Yes, I took it apart this morning and the metal blade has a molded on plastic nut that threads onto the motor shaft, and the plastic nut had all but disintegrated. The underside of the molded on plastic nut also helps to form a seal at the bottom of the SS container, and it was pretty well chewed up on the underside too.
We found another coffee grinder this afternoon for $20 bucks which is probably 1/2 what the Braun cost. Considering what the vet bill comes to for the diagnosis and meds, I guess another $20 bucks isn't so bad.
But 10 bucks for the one you found seems even better.
We have had luck with the Capresso coffee/spice grinder. After 5 years or so, it is still working. I have never tried it with pills, but see no reason why it wouldn't work. The only problem is that there is some caking of stuff directly under the rotating blades that I just scrape out with a spoon or something.
I bought a Regal Coffee/Spice Mill to grind tablets for Horses feed and it will reduce a large tablet to fine dust in about two seconds, I doubt I will use it enough to ever wear it out.
Thanks to all who responded to this wacky OT post.
Doug,
We tried a small blender but it did not crush the pills up very well, lots of big chunks.
Jim,
The machine we found for 20 bucks is the Capresso, and it worked ok this morning, for I'm not sure how many days worth of meds that my wife prepared with it.
Time will tell if it has the stamina for this job.
Fred,
Thanks for the actual 'field report' on the Regal for grinding up Horse feed/pills.
Lisa was just telling me that she has just soaked horse pills (800mg) in water to form a gruel, mixed in a little maple syrup and added that to a bit of grain. Or water soaked and squirted in the mouth with a large syringe like wormer (not my favorite way I'll tell ya, or the horses for that matter)
He's a Dutch Warmblood, about 18 hands. (Stable name is "BIG", real clever, huh?)
He's got a pulled groin muscle from doing something stupid out in the field one day. The pills are a muscle relaxer which I guess help keep him from going nuts on just stall rest and no turnout, just a little hand walking.
As with most Horse injury's, time is the main ingredient in the healing process.
We board him a few miles away, so the meds need to be powdered so the barn help can just dump it in his feed.
If we had him here, we would undoubtedly use the dissolve in water, add molasses or applesauce and use a giant syringe to shoot it into his mouth method.
These pills have a very bitter taste. I don't know why they don't make more equine meds that would taste good to a horse, rather than us horse caregivers having to do all kinds of creative cartwheels to get the horse to take his pills.
