Re: Router Table
George Colonel's Workshop-Havertown PA
Good Afternoon Lynn,
I have the JessEm MastRLift device and 7518 retrofitted in my 2nd table inspired by Norm. No problems. I used Bowling Alley block for the top. I also built the top and cabinet oversize to accommodate the cutters and accessories. Four drawers on left side; three on right plus switch.My 2nd version has lower shelf where my hand held #690s are accommodated. I use a commercial fence by LCMS. Extruded aluminum. High and accurate, and much better than Norm's original version. Cabinet is plummed for DC, and fence has vacuum port. DC is fair inside cabinet, and does require vacuuming. DC at fence is outstanding thru 2 1/2" shop vac port. My table is on casters. Also retrofitted "T-track" within table top for finger boards, commercial fence has T-Track installed already.
Norm's original plan called for modular construction. My first cabinet used that principle, and it is good for job site work. My #3 son uses it in his contractor work. My 2nd cabinet is integrated to a single unit and is a permanent shop fixture.
Pix show 2nd version prior to installation of lift and 7518 router.
George
