Opinions on AutoMach Power Carver?
Ron Bauman
Thinking of buying one and just want to know what folks think of them. It's for roughing out, not detail work. TIA.
Re: Opinions on AutoMach Power Carver?
Could you be more specific?
Keith Newton----Little Rock, Arkansas
I use mine more for finish carving than for roughing out.
I go for my rough shape with chain-saw, band-saw, arbortec or lancelot cutters in right angle grinder, coarse disk in angle grinder, then just use the carver to put the final carving details on the surface.
But then, if your projects are small enough, it may be fine for rough out too.
It sure makes life easier for me, but my hands are not what they used to be.
Re: Could you be more specific?
Ron Bauman
Yup mine are smaller. Just want to get some material out of the way before the detail work. Thanx.
Well, It sure takes a lot of the effort out of advancing the blade, and is a lot faster than chisel and mallet. As least it is for me.
But in a dry hardwood, don't expect it to be a hot knife through butter when you get up 5/8" wide blade, across the grain on are dense wood.
But if you are carving green medium density wood like cherry, you won't believe what a pleasure carving can be.
I have only played with one a little. I have one of the older Ryobi reciprocating carvers. The Automach is much better built and vibrates less so it's a lot better to use.
I don't know what kind of roughing you are talking about. With the right cutters it will take off quite a bit of wood. It will also let you cut very delicate cuts. To get started on a really light cut I simply hold the collet back with my finger so it starts the recipricating action before it touches the wood. That give me a lot of control.
