Cabinet reinforcement
Gary Smyth
One day job looks bad. I need to reinforce a wall cabinet in a pantry circa 1970. The owners went away for the day. Over time the cabinet has been overloaded with canned goods and the cabinet was coming away from the wall at the top. About 5/8�. I unloaded the cabinet. Placed a scissors jack underneath and got it back in the original position. Level and plumb. I made some battens to fit under fiberboard shelves to both straighten them, add support for goods and add additional screws to the wall to support the cabinet. I�m working alone and taking down the whole thing is NOT what I want to do. #1 what screws do I use. I figured 2 �� round head or oval with a washer. Any other suggestions? #2 The back of this cabinet is made of 1/8� fiberboard. If go through the batten and the back wall I�m thinking I might pull it away from the cabinet? I�ve shimmed to hold it to the cabinet but jeez, 1/8� fiberboard? It appears to be held on with staples. The cabinet is 42� wide with two studs to screw into, neither near the vertical sides so I can�t go diagonally from the cabinet sides into a stud. Any suggestions as to how I might anchor that piece of junk cabinet to the wall? I have access to the bottom of the cabinet but not the top. It looks like the cabinet was originally installed and then the ceiling finished. I'm hoping that the time I took writing this will be worth the result. Time�s a runnin out.
Re: Cabinet reinforcement
Joseph Mulherin
Gary, I am suggesting you use some angle brackets inside the cabinet...screwed to the sides of the cabinet and use expanding drywall anchors thru the back into the wall. Use at least 4 brackets...two on each side.
Dale Lenz
Dale Lenz
1.Proceed with the wall screws carefully and watch fiberboard, stop at some point if needed. I have always used dry wall screws, not the best maybe but I've gotten away with it. Use the screws that are not threaded near the head, less prone to break.
2. Install decorated cleat on bottom outside of cabinet, maybe make the cleat multi-functional, put coffee cup hooks in it, for a panty(?), but you get the idea.
3. Install screws through the top of the cabinet to ceiling rafters, use wooden strip as you did on the bottom of shelves if needed. It appears the cabinet is pulling down from the ceiling and the fastners would do the most good here.
Like you, I hate working on shoty stuff! You and I know the best fix would be to replace the cabinet, not always an option or so it seems.
Good Luck!
Jason Roehl in Lafayette, IN
You've been fortunate.
Drywall screws are terrible for cabinets for a couple reasons.
1. They have a bugle-shaped head--this is a wedge that can cause wood to split when it's in a torqued load situation like a cabinet, even if the hole is countersunk.
2. Drywall screws are not rated for the loads a cabinet typically sees. A cabinet might get 4 screws if it's wide enough to span a stud bay, and weigh upwards of 200 lbs loaded. A 50-lb sheet of 1/2" drywall will typically get 28 screws when installed on a 16" O.C. stud wall.
Jason
Get some 3 1/2" cabinet screws. They may be black oxide coated (like a drywall screw), but they'll have a lag (unthreaded portion), the shaft will be thicker, the head will be a washer head (wide, flat shoulder, not a bugle shape like a drywall screw), and you may have a choice of drive between square and philips.
Pre drill that top "batten" to just less than the size of the shaft of the cabinet screw--about 1/64" less, then run the screw in. When you see the batten just start to flex, stop.
If you're concerned about the cabinet pulling away from the cabinet, you could run a couple smaller screws into then end of that batten from the side of the cabinet. At the very least, I would glue that batten in if you haven't already with some construction adhesive.
If that still doesn't work, I'd tell them that they need a new cabinet. That one is definitely on the lower end of quality...
Jason
Dale Lenz
Agree. your fastners are better.
Dale Lenz
