getting the most from a rechargeable batttery
Bill Tindall
In posts below people report their unfavorable experiences with rechargeable batteries and some then eschew them for ever, perhaps unjustifiably.
Facts: The Prius runs on nickel metal hydride batteries (NiMH) which will last for thousands of recharge cycles. They use the best batteries and as important they have have sophisticated electronics to control how they are charged and discharged. Old pacemakers ran on nickel cadmium (NiCd) batteries some of which have lasted more than 15 years and undergone thousands of recharge cycles. The bottom line is that with the proper selection of the battery , the charger and the charging procedure rechargeable batteries do provide good value for portable power. The typical design target for a quality portable tool NiMH battery is 500 cycles, and for Li ion 1000. The converse is if you are not getting good value from rechargeable batteries you either didn't buy a quality battery, a quality charger and/or you aren't treating them with care. Furthermore, there have been great advances in battery chemistry and engineering in the past few years that have led to greater energy in batteries and longer cycle life. Hence, experience of some years ago may not be relevant to the battery you would buy today.
So steps 1 and 2 to optimum battery life is to buy a quality battery and charger. Step 3 is to treat it right.
The following factors adversely affect battery life. All rechargeable batteries, including your car battery, don't like to be used, or recharged, either hot or cold. They are most content where people are content. Over discharging or over charging leads to premature death. A quality charger will prevent overcharging; a cheap one may not. You can prevent over discharging by not running them into the ground before recharging. NiMH batteries are especially picky about how they are charged and if you are not willing to spend some bucks for the best charger this battery type is best avoided. Lithium ion batteries are more forgiving during recharge and many tools or battery packs have battery management electronics built in to prevent over charge, over discharge or operation at elevated temperature. So one may experience better value from Li ion batteries not because they are inherently better but because they are managed better.
Re: getting the most from a rechargeable batttery
Tony - Memphis
We deal directly with some cell manufacturers and some battery pack vendors and the rule thumb they/we use for Li cell charge cycles is 400. I wish we could get 1000. Now, that is defined as a full cycle. Basicaly, for us, it is about a year. We push them to 1 1/2 years though. Seems like that is when the lower capacity starts to be an issue. Another big issue with Li cells is temperature. That can have a large affect on battery life.
Tony
economics of rechargeable
Bill Tindall
Let us take Tony's data and apply to a drill. $40 battery and 400 cycles. That's 10 cents per battery charge. hard to beat that with an alkaline battery. Then one can determine if 10 cents per hour of use (to pick a number) is worth the convenience of the cordless drill.
