Home-made rail system?
A.J. Hamler
A.J. Hamler
Got an e-mail from a total stranger -- thoughtfully referred to me by a friend -- who wants to make his own rails for table saw, using angle iron and 2�x3� steel tubing. He wants to attach the angles to the front and back of his table saw (flat portion of the angle down on the front and up on the back). He wants to �rest� the 2x3 steel tubing on the angle on the front, and drill/screw it in place.
Sounds OK so far for a decent rail system, but he seems to think that once he�s made the angle/tubing rail on the front that any commercially available T-square type fence will fit right on it. He specifically notes that he�d like to put either an Xacta or Biesemeyer fence on his shop-made table saw rails, and I�m doubting that either, and certainly not both, would just go right on there. Even if they would fit and clamp on securely, I'm thinking he'd have a devil of a time ensuring the fence was square every time he used it.
I don�t have either an Xacta or Biesemeyer fence, so I can�t really go out to the shop and do a close examination of the clamping/mounting mechanism. However, I do have another T-style fence on my table saw and after taking a close look at it, it�s obvious it would never work on such a system.
Apparently, buying rails made for either an Xacta or Biesemeyer fence system is out of the question, and he wants to make his own.
Any thoughts?
Re: Home-made rail system?
An Exacta rail is "exactly 3" wide by 2" deep so see no reason why the fence won't fit. He'd better finish the steel, though, preferably with powder coating to get a smooth riding surface.
The rail on my Biesemeyer fence is also 3" by 2". I did not measure the angle, but if there is a "trick" to it, its getting the rail exactly the correct height below the table top and the correct distance out from the edge. Mine came with a bunch of pre drilled holes designed for various common saws, and it bolted right on. They sent a little template or jig that let you set the height just right. there was some up and down adjustment in slots. The fence has nylon pads that slide on the rail. The part of the rail that contacts the pads is about and inch wide on the top and on the front and rear of the rail. These stripes are milled smooth and fairly polished. I am not a metal worker, but to me the polished stripes would be the hardest part. They may have lacquer on them, but they appear to be bare metal and I have waxed them. There is an angle iron on the far side, but it appears to do nothing other than support the wings.
Other than polishing the wear surfaces any semi competent metal worker should be able to make the rail system. And a metal shop might be able to provide the polishing. I would probably do it with a belt sander.
If I had the fence, I would probably make my own rail out of something like MDF and cover it with smooth plastic laminate. I have a friend who made a tenoning machine he uses in his cabinet business. The table and rails that slide in slots in the table are all covered with Formica. When he built it he was skeptical about the life of the plastic laminate so he made a complete set of spares. After thirty years, he is still using the original and it shows very little wear.
I might even try an oak or other hardwood beam, but then, I am a wood worker.
A lot of angle iron is subtly tapered on the inside, from corner to edge. He should check that on the iron he gets - shimming the tubing to square could be a hassle.
It seems like that's a recipe for sawdust to fill the gap between angle iron and tubing. Ideally, fastening the angle iron only where there are holes - making little brackets, in other words - would avoid this. The trick there would be getting the holes drilled so that the brackets are in a line. Maybe he could assemble the angle iron and tubing first, get everything all aligned; and then take it apart and saw off all the angle iron that wasn't connected to either table or tubing.
A.J. Hamler
A.J. Hamler
So it sounds like it could be done, as far as the fence fitting on that 2x3 tube. The key, I'm thinking, is getting that tube positioned exactly right vertically so the fence lies flush on the table top, as Barry noted.
It seems to me that if you set up this home-brew rail system, you'd absolutely need to have the fence you intend to use FIRST so you could get the position exact when mounting the home-made rails by using the fence as a guide for positioning the home-made rails. I don't see how you could do the rails first, and then hope the height is exactly right to accept the fence.
Now, if you did this to fit, say, the Biesemeyer, it wouldn't automatically fit the Xacta too, would it? (Or any other T-style fence, for that matter.)
A.J.
Bruce, a MN Galoot
Back in the Badger Pond days there was a series of posts by a woodworker from Scotland, whose name I've misplaced - we had corresponded for a while. Anyway, he had made an exact copy of the Bies fence and rails using off the shelf rectangular tubing and angle iron. If you do a search for homemade Biesemeyer or homemade tablesaw fence, you'll find what you need. IIRC, FWW had a couple articles on these as well.
I absolutely agree. Buy the fence first. Otherwise you are just guessing.
While angles may be slightly tapered on their interior surfaces, I do not recall any evidence of milling on the interior surfaces. I think in fact they are close enough to square for this application.
I still have the instructions that came with my Beis fence and the little pattern of gauge they sent with it to set the height. I don't recall the number, but it was something a little strange like 17/64". Nothing wrong with it, just struck me as odd they would make it something like a 1/4". If it is important to your friend, I could pull out the instructions and relay the info to him, I could fax them or scan and E-mail Them.
It occurs to me they could have let the fence slide on the table at the near end the way it does on the far end and then the height of the rail would not be critical at all. Maybe they have some engineering reason for having it ride the rail, but it seems to me it would work the other way also.
Steve Schoene
How could someone expect to have a one off custom product, designed, material acquired, and fabricated, at a price that isn't at least double what the mass produced product would cost?
A.J. Hamler
No idea
A.J. Hamler
Not far from what I was wondering -- plus taking into account the amount of work to make it and the fact that no home-made rail system would ever be as good as the one designed specifically for the fence -- but that's what they guy wanted to do.
No idea why. But, I was just trying to answer his question about the possibility of it all mainly as a favor to the friend who sent this guy to me. No idea how experienced a woodworker he is. If anyone else had asked -- someone from here, say -- I would have just said to go out and buy a real one. It'll be cheaper in the long run, it'll work perfectly, and it won't take nearly as much time.
