We value your privacy.
What is the trick, well, maybe not a trick, but how does one get a good, smooth sanded finish on Russian Olive? Its got that hard/soft grain that I find difficult to get an even smooth finish. I'm a total newbie to this site and my computer skills are 101 page 2 but it looks like a neat place. I live at Ft. Peck, Montan and we have an abundance of Russian Olive.
Southern yellow pine and others, like probably D. Fir that has a hard summer wood with a relative soft spring wood will do the same thing if you sand with a soft pad. I semi glue a piece of tablet cardboard between my soft sanding pad and the sandpaper and results in a smooth surface. Might try this and see if it helps.
There is a good way to deal with hard to sand woods. It is called a cabinet scraper .
Sorry - I just had to say that. I've "stiffened" the wood with wash coats of sanding sealer or light coats of a wiping polyurethane. But that is usually for REALLY cantankerous wood (like spalted soft maple). It also uses up sandpaper rather quickly.
I usually use my large sander (1/2 sheet). The extra surface area on the sander makes it easier (IMO) to get a more even surface on the work. I will also use a bigger sanding block. You don't say which sandpaper that you are using. Sometimes when I have trouble sanding wood with one type of sandpaper, I switch to another type. I.E. if I am using aluminum oxide, I might switch to garnet sandpaper. Garnet sandpaper usually wears out faster - so my usual sandpaper is aluminum oxide.
JL: I've been using Abranet screen, which I find far superior to paper or cloth backed paper, but still doesn't give the finish I'd like. Going to try Dale's harder surface. Thanks for the input.
First, welcome to Woodcentral. It is a great place to hang out; I learn as much from the off-topic (OT) posts as I do from the woodworking related topics.
I have no experience with Russian Olive, but JL's suggestion sounds good to even out the smoothing of the hard and soft areas of your wood. To clarify a bit, I would go with what is know as a card scraper (aka cabinet scraper). It is an amazingly simple hand tool that is well worth learning how to sharpen and use. I have much less experience with another version of "cabinet scraper" that has handles and a much thicker cutting blade, although I have used it for glue removal between joints. Give the card scraper a try and let us know how it (or any other solution) works out.
Welcome to WoodCentral. This is a fabulous place with lots of knowledgeable helpful people.
To or three things on the sanding.
One, the card scraper mentioned above is a great idea. A piece of ancient technology that deserves to be kept alive. I have only recently started using one and I am amazed at what I was missing.
Two, as for actually sanding, use the harder backing plate mentioned above and larger is better. Not mentioned, use fresh SHARP sand paper. You should use sandpaper like you stole it or found it it or bought it with somebody else's money. Dull sandpaper fails to cut the harder parts of the wood and wears down the softer parts, particularly if you are sanding with your finger tips or soft pads. So, change paper often. Sharp paper tends to cut the harder wood better. And, cycle through the grits.Start at whatever grit you think you need and then step through the grits quickly and don't skip any. Maybe 80/120/150/180 and that's it. Sanding beyond about 180 or even 150 is usually wasted effort on flat work.
That's really beautiful country up there where you are. Back when I worked for NOAA, we set up a solar radation field site just east of you over by Poplar. I spent a few really nice weekends up there doing the work a few years back. Even got to go back to do maintenance stuff.
What others have said is great advice for turning. I spend 90% of my time in front of the lathe as well. I find the table saw a good place to set blanks before I can get to them! I get the best results from careful turning with a really sharp gouge, so that it minimizes the sanding.
If you ever want to try something southern, I am in North Carolina now, so drop me a note and we can do a wood swap. Those flat rate shipping boxes from the post office make for easy sharing of wood.
Take care,
Mike
Memories of the wild west in the settled east in Apex, NC!!
