A short course on batteries
Bill Tindall
Alkaline batteries: cheap per unit of energy provided, long storage life ( nearly forever in the frig. and at least years at room temperature). Poor short burst of energy capability. The rechargeable version have short life. Best for intermittent low power needs like an emergency flashlight or smoke detector or tools that are occasionally used.
Nickel metal hydride- rechargeable, high initial cost, exceptional energy density and exceptional peak power capability, ordinary versions discharge quickly when not in use(poor shelf life) but this loss of energy is recovered by recharging, require a sophisticated (expensive) charger to obtain optimum useful life. The better version do not suffer "memory effect". Poor choice for a smoke detector or emergency flashlight that would sit unused for months. They power the Prius. Designed to deliver about 500 recharge cycles but when optimally maintained can deliver nearly 10,000 discharge/charge cycles. China has the market monopoly for a critical component of this battery (the rare earth anode).
Lithium Ion- These are hugely complicated batteries and they come in many subtle varieties. In their most optimum form they deliver more energy per battery than Nickel metal hydride but in the cylinder form they are about equivalent. Don't require sophisticated charger. Typically designed for 1000 charge /discharge cycles. Better shelf life than Nickel metal hydride.
All these batteries entail complicated chemistry and engineering. The best and hence most expensive batteries are made with better materials and better packaging which will lead to longer useful life and more energy per battery. Especially with Nickel metal hydride, a cheap charger will lead to short battery life. Expect to pay about $40 for a quality Nickel metal hydride charger.
Heat kills batteries as does overcharging. Over discharging kills batteries but many devices have low voltage cut-offs that prevent over discharging.
Most of the recent battery developments have been out of Japan. I would expect Japanese and US made batteries, and maybe Korean, to be of best quality and hence best life.
