Knife block wood orientation (and dimensions)?
In our remodel of the church kitchen, we put up a 1/2 wall that contains electrical and plumbing service. We have two 8' x 2' stainless tables on either side of the wall. The top of the wall is capped with stainless. This is about 6" or so wide.
What I would like to do is put a knife block on top of the wall. The knife block would be oriented so that it straddles the cap on the wall. The handles would jut out so that they are over the inner edge of the tables and work surfaces. I figure on putting cleats on the bottom of the block so that it would "lock" the block onto the top of the wall - yet be easily removable.
I was figuring on gluing up a large number of strips (probably of cherry as I have a lot of it). I was figuring on having the cleats go "across" the grain - and I was thinking about just putting the cleats in dadoes. I was probably going to cut similar dadoes and put strips of wood on top to hold the knives in the block.
Any particular way to orient the wood for the block itself? As I am cutting strips, I could do just about anything. I was planning on cutting "partial" kerfs in the edges of the strips before gluing the strips together. Probably about 1.5" or so "tall". How wide is "standard"? Should I go for a full 1/8", 3/32" or what? I was planning on using Titebond II to glue. I was planning on "finishing" it with butcher block mineral oil.
If anyone has any other suggestions, I'll happily read them.
