OT - Table Top Finish repair question
Joe in a Cleveland suburb
Hi all.
I have dining room table that has some finish problems. I don't know the history of this table, but knowing the previous owner of it, I would guess it was bought new in the 50's or 60'. The top is veneer.
The problem is people have put hot plates on the top which left white hazy looking areas. There is also a white ring now.
I don't know what the finish is. I put a drop of denatured alcohol and a drop of lacquer thinner on it and neither softened the finish.
I tried putting mayonnaise on one of the areas and it had no affect. I also wiped it with paint thinner. This made the spot disappear, but it reappeared when the thinner evaporated. I also tried, just for kicks, applying some Liberon wax to one of the areas. It didn't help.
Any thing else I could try short of refinishing the entire top?
I plan on getting rid of this table soon so I wanted to clean it up a bit.
Thank you.
Re: OT - Table Top Finish repair question
Clint Searl
Clint Searl
If it's Salvation Army grade, I'd do nothing. If it does have any value, I'd strip the top and refinish with something visually compatible with the rest of the table.
Clint
George Colonel's Workshop-Havertown PA
Good Morning Joe,
I think Clint is right. Before you refinish, you may want to use a more aggressive abrasive. I'd try cigarette ash, or rottenstone in very light oil, gently rubbed with soft cloth to release underlying moisture. Then try polishing the area.
George
FredD
Following the Colonel idea , somewhat less messy approach is one of Mequiars rubbing compounds available in any Auto parts or Paint store.
Use the one that says "for finish damage "
Using a soft clean cloth rub it out by hand and if that doesn't do the rick I would be surprised.
FredD
Steve Schoene
Wiping with paper towels dampened (but not wet) with denatured alcohol is likely to give a more permanent fix for the white rings, than paint thinner.
Unless refinished subsequently, I can't imagine factory furniture from the 60's with anything but a NC lacquer finish.
From the description of MS "making it disappear" (but coming back), I have to interpret that as heat fracturing of the film coupled with water infusion. Have to agree with the NC lacquer comment. But so, what to do? If it's worth saving (Salvation Army doesn't take furniture in my area, Goodwill either), I'd carefully sand the top surface to the bare veneer, wipe it well with Lacquer thinner, and, when dry, refinish the top.
Thanks all for the suggestions and taking the time to reply.
Last night, I tried the above suggestions. No joy.
I tried:
pumice stone FF with mineral oil.
rotten stone with mineral oil.
a couple different auto finish repair products (Meguires)
rubbed with denatured alcohol
rubbed with laquer thinner (made it a tad soft)
Liberon wax
No luck.
I agree it needs to be completely redone. This piece is definately not Salvation Army quality. I has hoping to sell it once cleaned up or pass it down to somebody after I removed some of the abuse we've given it over the last 15 years.
Maybe I'll take it down the road and hand it off to Jeff Jewitt to work his magic on it. That might cost more than it's worth though. His shop is about 8 miles from me. Does anybody have a truck I can borrow!? :)
Thanks.
