spray booth design
spray booth design
spray booth design
McKay
I have just finished the walls of a 7 x 10 room that will be my spray booth. I have the fan installed and now I need to finish the insulation and sheet rock. My question is: Do I want to taper the walls toward the blower fan or do I want to curve the walls? I believe that the air will travel faster with either tapered or curved, but it seems that the air would find less turbulence if they were curved toward the fan rather than encountering a sharp angular transition.
I tried to include a sketch up drawing, but I got a prompt saying that it was in "invalid format". So hopefully all will understand what I am asking.
Thanks in advance. :(
Re: spray booth design
Jesper, Denmark
Jesper, Denmark
There is no need to taper or curve the room towards the fan. Ideally you would want a steady flow from the entry across the painted piece, with the painter on the upstream side of the airflow.
A bell shaped entry to the fan suction will improve the fan performance, but not make much difference to the airflow in the booth.
In an industrial situation, the rule says that the flow across the opening to the booth needs to have 100 fpm flow velocity to avoid overspray escaping from the booth. In a non-commercial shop, you can get away with less.
Moses Yoder
Moses Yoder
Normally you are spraying in line with the fan, so the air is moving striaght from you to the fan. If you spray larger objects and move out at an angle to the fan, the air is still moving straight towards the fan so it still moves kind of in a straight line from you to the fan. As mentioned above, I have never seen a spray booth with taperd walls and for spraying large objects they would get in the way. The object you are spraying can be moved closer to the fan with straight walls. The spray booths we work with have a large filter in front of the fan to catch overspray. If you use a filter like this, let it dry thoroughly before throwing it out in the trash or it can self combust.
In the same vein
Gary Smyth
Whatever configuration you use be sure that the fan motor is enclosed and that fumes and spray from some of the liquids you will be spraying cannot ignite. I had a neighbor that was surprised with a bang and fire when he was spraying, and then turned on an inexpensive 20" house fan to vent the area.
