One more Jig question
Greg Muller
When useing one of the router mortise and tenon jigs what type of bit should I use?
Greg Muller
Re: One more Jig question
Jim Dillon
Greg,
I've had excellent luck with spiral bits. Most of my spiral bits are upward spiral as they will clean out a deep mortise better than a downward spiral. But a downward spiral will leave a cleaner edge around the mortise. Your call. For shallow mortises, say for hinges, where you may be working with thinner material and the mortise won't be covered up, a downward spiral is better IMHO. Most of my spiral bits are from Whitesides and they have worked well. Hope this helps.
Jim
spiral bits
del schisler
Thank you All
Greg Muller
