The Zen of the edge joint
wilbur
Like the BBE, or maybe in conjunction with the BBE, a non sprung joint is supposed to prevent some calamity when boards are joined together by ensuring that the edges match. In the olden days it was a gotta-do before gluing up a panel. There are still adherents to the practice. I think it had something to do with experience showing that the joints at either end of the glued panel had few issues with possibly pulling apart even though the end grain would dry and shrink faster than the interior of the boards. But that can't be right because a poster on the BBE thread asserted that hide glue from the local abattoir wouldn't have failed.
Anyway, let's see if I have the drill correct. After selecting all the boards for a table top, which have been S4S jointed and planed so that they're all the same thickness and the joints are all a perfect match, and are all at 6-8% moisture, I'm supposed to then hand plane the interior edge(s) of each board so that every joint will be perfectly matched along its length. Then I can do the glueup and pull everything together with massive clamping, or is it cramping, pressure. That's what FWW tells me.
I hope someone can explain why I would want to do that when I've never taken the time to do it before and have never had a problem with quickly making a sprung joint.
Next time we'll explore the Zen of the dovetail joint.
Before I get inundated with replies, I am not being serious at all with the above passage. There are advantages and disadvantages to making a sprung joint. The same holds true for edge joints that are not sprung. Both will yield excellent results, and it would be impossible to tell which method was used to glue up a panel by examining the panel afterwards.
I just wanted to point out that the existence of one method of work for a given task does not invalidate other methods of work for the same task. Otherwise, we'd all be using Japanese woodworking tools.
